Re: How much clearance between oil pan and drag link?
[Re: Jeremiah]
#2036413
03/22/16 01:02 PM
03/22/16 01:02 PM
Posts: 1,213 Minn
SportF
Minn
If this is the same center link as a 63 B body, the link fits on two ways. There is about .75 inches in clearance between the two. It looks like it won't make a difference, but it does. And it would seem the "right way" the link looks, is actually the wrong way.
As I recall, the link, shaped like a "U", the bottom of the "U" goes to the front.
I checked a bunch of cars at the track last summer, and everyone, including my race car, was on backwards. Handling and geometry are the same either way, but it makes a clearance difference.
[Re: Jeremiah]
#2036569
03/22/16 04:54 PM
03/22/16 04:54 PM
Posts: 4,209 New York
polyspheric
New York
Cars with conventional rubber motor mount biscuits need more safety clearance than with polyurethane biscuits, which need more than engines with motor plates. If you smack the link hard enough to do anything, your toe and bump steer will go out.
Boffin Emeritus
[Re: Jeremiah]
#2038217
03/25/16 01:37 AM
03/25/16 01:37 AM
Thumperdart
State of confusion
Any others want to weigh in on this topic? Man, this place has really dropped off! C'mon back! Why not, elephant ears, rubber trans mount and I have very little clearance between the link and pan maybe 1/4" and it hits the pan on full turns.............
[Re: Jeremiah]
#2038525
03/25/16 03:04 PM
03/25/16 03:04 PM
Thumperdart
State of confusion
Thank you Dom, that's what I was after. This car is going to retain the stock mounts for now. The black car has a motor plate so I'll be asking again when it's time comes!
4150 carb, stock style motor mounts, stick shift...nothing to be scared of for the casual onlooker. Well, other than the body style. It's a '66 Charger and that will frighten almost anyone! I`m frightened just thinking about it...........lol!
[Re: Jeremiah]
#2038543
03/25/16 03:23 PM
03/25/16 03:23 PM
Posts: 368 michigan
turbo toad
michigan
This is a low deck in a 62 valiant with a V8 Drop link theres about 1/2 of a inch of clearance. If you need a more accurate measurement let me know and after i got out of work ill take a better measurement
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: Jeremiah]
#2044643
04/02/16 07:18 PM
04/02/16 07:18 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I had to do this on my 67 Fury - This is with the steering all the way one way - I really wanted that fabbed aluminum pan to fit!
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: Jeremiah]
#2046123
04/04/16 11:21 AM
04/04/16 11:21 AM
Posts: 1,237 North Central, Indiana
Roughbird72
[url=[URL=http://s45.photobucket.com/user/bubby440/media/20160403_184318_zpstbzhtidf.jpg.html] [/url]]pan clearance[/url] This is an old Proform pan i've been running on my Roadrunner for 25 or so years, there's 3/16 clearance.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2046172
04/04/16 12:30 PM
04/04/16 12:30 PM
Posts: 1,213 Minn
SportF
Minn
[url=[URL=http://s45.photobucket.com/user/bubby440/media/20160403_184318_zpstbzhtidf.jpg.html] [/url]]pan clearance[/url] This is an old Proform pan i've been running on my Roadrunner for 25 or so years, there's 3/16 clearance. It is a little hard to tell from that photo, but I believe if you swapped that link end for end, you'd have more clearance. I know it doesn't seem like it makes a difference, but it does. Edit I didn't see what 71 Charger said above, but it is an example of the difference in how the link is on there.
[Re: Jeremiah]
#2046240
04/04/16 01:54 PM
04/04/16 01:54 PM
Roughbird72
The link in my car has no significant difference from one end to the other. I have had no issues thus far.
[Re: Jeremiah]
#2048135
04/06/16 05:34 PM
04/06/16 05:34 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Be sure youre steering wheel is centered, and for that matter the box being indexed correctly on the pitman. Ive heard some replacment worm shafts dont have a master spline, so you can be off somewhere in the mix.
I had a 31580 milodon hit just before full lock turning right. I hadnt aligned the car since I had it and a stock pan cleared fine. Centering things up like they shouldve been provided the needed clearance.
Torque strap is a must with stock mounts. I think you will be fine after checking these details.
I want my fair share
