Vacuum Advance with Hemi Cross Ram #2035694
03/21/16 01:24 PM
03/21/16 01:24 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
Anyone use vacuum advance on a gen II hemi cross ram engine? I have the reproduction MP cross ram manifold with removable tops and a pair of 650 cfm Holleys. I wasn't sure where to port the vacuum advance. Should I T together off both carbs? Off one carb? Don't use? The car will see mostly street duty with occasional strip. I have had locked out distributors before on other engines. I am just looking to see if it has been done or could be done.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Vacuum Advance with Hemi Cross Ram [Re: RoadRunner] #2035723
03/21/16 01:58 PM
03/21/16 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont need to T in both carbs.. the signal
will still be the same.. for a street car the
vac does help on the MPG but you need to curve
the can and the dist to match the engine and
weight of the car for your cruising conditions
wave
Re: Vacuum Advance with Hemi Cross Ram [Re: RoadRunner] #2035987
03/21/16 08:44 PM
03/21/16 08:44 PM
Thanks. Somewhere I have a couple of articles on adjusting the can. I've welded and files slots to get the right advance, so no issue there. I am not sure how the vacuum advance can works so that will be new territory for me.
2023 Ford Mach 1
Re: Vacuum Advance with Hemi Cross Ram [Re: RoadRunner] #2036004
03/21/16 09:20 PM
03/21/16 09:20 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
I think there was a series of articles in mopar action magazine that went through in detail about running vacuum advance, centrifical advance,etc... you can probably search their website and find them. I think rick Ehrenberg wrote them. not too long ago.
