Re: Engine dilemma
[Re: Eggman]
#2036020
03/21/16 09:40 PM
03/21/16 09:40 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The only issues that I would have is that of compatibility with the existing torque converter and oil pan fit. If the 318 has a truck pan it will fit the truck chassis, if the 360 has a truck pan it will fit the truck chassis, if the 360 is internally balanced it will bolt up where the 318 was with a neutral balance converter or you can use one of these or weld the weights on the converter, but changing the flexplate is easier. JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Engine dilemma
[Re: Eggman]
#2036610
03/22/16 05:44 PM
03/22/16 05:44 PM
Posts: 15,487 Florida
scratchnfotraction
I am running almost the same 318 combo in my 85 stepside.
91-#302 headed 318
holley 6210 650cfm spredbore dbl pumper holley street dominator intake 1/2" 4 hole spacer hedman headers 2.5 duels 2 chamber muffs turned out at the steps NV4500 5 speed 9 1/4 3.55 locker 29x11.50x15
I have also run the a999 stock HS/LU-TC as well as a 727 stock HS non lock-up trans in this truck. very happy with all 3 trans combos on this whiplash 318.
I run a 440 whiplash in my 88-440 truck stock LS-TC with a 2.76 gear 29x15x15 M/Ts super happy with this combo and only gets better swapping in 3.23 or 3.91 to play with.
I would save the coin on swapping then swapping to A-body my self.
does the 360 have a whiplash cam as in GOODYS?
is the 360 build more of a race engine or street engine?
street is neat and race is..well racing.
