Re: Wreck at Gainesville
[Re: Roughbird72]
#2035724
03/21/16 01:58 PM
03/21/16 01:58 PM
Posts: 11,840 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Happened Friday morning. The first 2, and the only 2 cars, to go down the track. Then they gave up until the afternoon. Lucky no one got hurt.
[Re: Roughbird72]
#2035731
03/21/16 02:07 PM
03/21/16 02:07 PM
Posts: 1,238 North Central, Indiana
Roughbird72
Very lucky no one got hurt. Makes me wonder if they even checked the track before sending them down it.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2035741
03/21/16 02:18 PM
03/21/16 02:18 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
That's why I'm never the first guy down the track.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Roughbird72]
#2035745
03/21/16 02:25 PM
03/21/16 02:25 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Very lucky no one got hurt. Makes me wonder if they even checked the track before sending them down it. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) You'd think they would have seen that much water on the track if they'd actually looked.
[Re: justinp61]
#2035789
03/21/16 03:44 PM
03/21/16 03:44 PM
Posts: 43,375 Bend,OR USA
Cab_Burge
NHRA always sweeps and preps the track before any car goes down the track for the first time each day. You can see one of the Safety Safari guys run up to the concrete barrier and look at the second car real hard before opening the gate for the truck to go out to the wreck. I thought that maybe it was raining on the far end but the Safety Safari guys would have called the tower on thier radios to tell them that ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I have heard of some tracks(Speed World in Phoneix, AZ is one) that have probelms with water coming up through the track when the track warms up ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Bottom line is both drivers lost control after the finish line when they let off so something abnormal was on the track down there, more than likely ![work work](/ubbthreads/images/graemlins/custom/work.gif) To bad, I hope no one got hurt at all ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
[Re: Roughbird72]
#2035837
03/21/16 04:56 PM
03/21/16 04:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A lot of these tracks will weep water up through them after heavy rain. Can't do anything with it except wait for the water table to drop. Don't remember where it was, but I've stood on the fence and watched water squirt up out of a track like a water fountain after a hard rain.
Track was weeping and actually, if you look at the timing blocks, they both lost control right after the 1000'. Unless something has changed, with the fuel cars running to 1000', NHRA doesn't prep the national event tracks the same from 1000' to the 1320' because of damaging the tire they are running. "Chunking" was the term I remember them using. Top Dragster is as fast or faster than a Pro Stock. Shouldn't have happened.
Throttle stop cars are always interesting on those days. Get out there in the middle and roll the throttle back open and you need to pay attention to what it's doing. That's one of the reasons that a lot of those cars are run in high gear only when the stop comes back off.
[Re: gofish]
#2035847
03/21/16 05:04 PM
03/21/16 05:04 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
IMO it was pretty stupid to send such fast cars down the track first pass of the day.
Danny They tried to run Stock. They always stick those guys out there first when it's like that. But they couldn't get the cars out because the pits were so muddy and under water.
[Re: CMcAllister]
#2035956
03/21/16 08:22 PM
03/21/16 08:22 PM
Posts: 4,294 Morrow, OH
markz528
Morrow, OH
Where is Challenger 1? That got him in Columbus in his TAD.
[Re: Roughbird72]
#2036215
03/22/16 02:09 AM
03/22/16 02:09 AM
Posts: 19,403 Las Vegas
Al_Alguire
Las Vegas
Well when you can see the water coming off the tires not so sure how well they checked. And to start the day off with T/D time runs is ludicrous to say the least. Some of the fastest cars at a National Event are the T/D guys, someone dropped the ball big time telling them that track was safe for them to race on period!!
