Information is key to just say it doesn't shift is useless. What doesn't shift, the transmission or the transfer case? Is it an automatic or a manual? Does the shifter not move, or move with little or no resistance? Does it have reverse? Is it stuck in second or third? What Trans is in it? Check engine light on? Be specific about what works and what doesn't and how exactly it behaves.
