weird pvc/hose problem #2034289
03/19/16 03:14 AM
03/19/16 03:14 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Anyone ever have the PVC hose "sweat" oil? It never did this before only change is a switch from 20w/50 to 10w/30, and 750dp single plane to 6 pack. Could it be a stronger vacuum signal from the small center carb? It doesn't seem to dump oil into the base of the carb,its actually pretty dry at the carb. Hose seems to just sweat by the pvc for a few inches. confused shruggy
Re: weird pvc/hose problem [Re: ademon] #2034298
03/19/16 03:30 AM
03/19/16 03:30 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's generally a sign of a bad hose.
- Stu Harmon
Re: weird pvc/hose problem [Re: ademon] #2034376
03/19/16 11:32 AM
03/19/16 11:32 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Make sure you use the correct mopar 11/32 pcv hose. Regular vacuum/fuel line hose is different.
Re: weird pvc/hose problem [Re: ademon] #2034875
03/20/16 03:49 AM
03/20/16 03:49 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Come to think of it, I did need a longer hose when I went from the 4bbl to 6 pack, I'll get true PVC hose. Thanks
