Who is the best value in custom pistons these days? #2032790
03/16/16 11:08 PM
03/16/16 11:08 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Might need something for a BB that doesn't match anyone's stocking part specs. Favorite piston companies seem to change with the wind... so which way is the wind blowing these days? Thanks, Brad
Re: Who is the best value in custom pistons these days? [Re: BradH] #2032795
03/16/16 11:12 PM
03/16/16 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you gonna run a standard over bore or
something off the wall... if its a standard
over bore then Diamond.. they will do 3 changes
before they call it custom and each change is
cheap
wave
Re: Who is the best value in custom pistons these days? [Re: BradH] #2032934
03/17/16 07:51 AM
03/17/16 07:51 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Since your post title asks for best value
http://racetecpistons.com/pages/autotec.php
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033154
03/17/16 01:40 PM
03/17/16 01:40 PM
Diamond or Ross thumbs twocents
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033172
03/17/16 02:01 PM
03/17/16 02:01 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Diamond
Mainstream Media is the new Pravda
Re: Who is the best value in custom pistons these days? [Re: JohnRR] #2033214
03/17/16 03:05 PM
03/17/16 03:05 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
JE
Re: Who is the best value in custom pistons these days? [Re: JohnRR] #2033217
03/17/16 03:10 PM
03/17/16 03:10 PM
dogdays Offline
dogdays  Offline
Each company has its followers. I wouldn't turn down a piston from Mahle, JE, Diamond, Wiseco, Racetech, CP, Icon. Probe pistons would be plenty good for my stock block non-racing needs. It feels like they're a little down the pecking order, maybe not quite as good. The ProTru and SRP lines are the lower priced lines from Wiseco and JE.
Then you have the old standards like Bill Miller and Venolia and Arias.
I believe there's a startup out there somewhere but cannot remember the name.
I think you either go with a Diamond and configure it to your liking, or you use a shelf stock piston from the others and build the engine around it.
If this engine is going to be used hard, you may consider finding out if single replacement pistons are available, or how many is their minimum. Or buy a set of 10 to start out.
ADDITION: I just checked out the Racetec/Autotec page and it looks like they're deserving to be in the mix. Here's why: Company was started by former owner of JE pistons, and, FREE CHANGES to a shelf stock piston. Compression height and bore were mentioned. They say anything that doesn't require a change to the forging can be accommodated.
Racetec is 2618 alloy
Autotec is 4032.
R.
Re: Who is the best value in custom pistons these days? [Re: GTS340] #2033302
03/17/16 05:21 PM
03/17/16 05:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My Dad and I put some of these in a 416 last summer. Nice pieces, He bought them through Molnar.
68 Barracuda Formula S 340
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033314
03/17/16 05:46 PM
03/17/16 05:46 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I think CP would be my choice for a custom piece.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Who is the best value in custom pistons these days? [Re: Eric] #2033327
03/17/16 06:08 PM
03/17/16 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF I had to buy custom it would be CP... I used
them for my W-9.. they made it to the head for
14.1:1... but if he just needs things moved a bit
it would be Diamond and save on the price tag
wave
Re: Who is the best value in custom pistons these days? [Re: MR_P_BODY] #2033423
03/17/16 09:09 PM
03/17/16 09:09 PM
dogdays Offline
dogdays  Offline
I'd check Racetec/Autotec for price as they seem to me to be the best value, and the free relocation of pin or custom diameter thing got my attention.
He did ask for best value, not the best double-throw-down no-holds-barred piston, right? I kind of missed that in my first post.
R.
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033429
03/17/16 09:18 PM
03/17/16 09:18 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
All the big names piston manufactures are good, I use to be a JE fan till it came time to get my custom pistons and they let me down on price for the build. I now am a Wiseco fan as they stood up to the plate and delivered in quality and price.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Who is the best value in custom pistons these days? [Re: dogdays] #2033479
03/17/16 10:25 PM
03/17/16 10:25 PM
Autotec is 4032.
R.
I'm under the impression the Calvert Bros. owned J&E and sold it with a 5 year no compete claused over 12 yrs ago that expired before they bought all new equiptment and opened thier new piston making company under the name CP (Calevet Performance confused)pistons. I seem to remeber that they bought Carillo connecting rods several years later also work
shruggy With all the buying out and reopening of performance manufacturers in our industry I can't keep up with who is where and what they now make and sell whiney
Re: Who is the best value in custom pistons these days? [Re: Cab_Burge] #2033530
03/17/16 11:32 PM
03/17/16 11:32 PM
BradH Offline OP
BradH  Offline OP
I've used JE and Ross most recently. I've had my hands on some Icon, Mahle, and Bill Miller, so I've got a reasonable idea about those brands. I own a set of CPs, and they are the nicest looking of all, plus they're very light. If cost were no object, it would be custom CPs... but they are freakin' expensive. That's why I'm asking about other options.
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033538
03/17/16 11:50 PM
03/17/16 11:50 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Post is interesting with my ears up. I've checked most all of them and can't see any Hemi pistons for a 4 1/2 stroke with 7.1 rod so I guess custom for me. $$$
Re: Who is the best value in custom pistons these days? [Re: cudaman1969] #2033558
03/18/16 12:16 AM
03/18/16 12:16 AM
BradH Offline OP
BradH  Offline OP
The custom RaceTec stuff has me curious... work
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033603
03/18/16 06:11 AM
03/18/16 06:11 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
And at under $500 for a set of catalog Autotec pistons with free changes to ring pack, bore, and compression height, and under $700 for a set of completely custom pistons.....you should be
Re: Who is the best value in custom pistons these days? [Re: GTS340] #2033874
03/18/16 03:00 PM
03/18/16 03:00 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Some excellent discussion/information in this thread! up
When you guys need a custom piston or a shelf piston with some changes, do you normally order straight from the company or go through a dealer? Is there a cost benefit one way or the other?
Re: Who is the best value in custom pistons these days? [Re: Jwilli500] #2033880
03/18/16 03:09 PM
03/18/16 03:09 PM
fullmetaljacket Offline
Diamonds are 4ever.
Re: Who is the best value in custom pistons these days? [Re: BradH] #2033932
03/18/16 04:22 PM
03/18/16 04:22 PM
AndyF Offline
AndyF  Offline
Are you ordering the pistons yourself? If so, you're just lunch meat for the wolves!
I usually have my buddy at the engine shop order my pistons so I can at least get jobber price. He also knows the guy on the custom order desk so my order doesn't get "lost in the shuffle".
I tried to order a set of custom pistons from Mahle a few weeks back. This was for a magazine article motor and they still never bothered to return my calls. I think I left 3 or 4 messages before I gave up. Ended up using Diamond for that project since their sales guy was willing to pick up the phone and take on the project.
