Re: Experience with Cast SCAT 4" with 318/340 Mains
[Re: Jwilli500]
#2033670
03/18/16 11:12 AM
03/18/16 11:12 AM
RapidRobert
Trying to get "off the fence" with some decisions here. No actual exp with it but I've heard good regarding their rods so I'd feel comfortable with that brand of crank no matter what the overlap is. A BTT for ya
[Re: RapidRobert]
#2033805
03/18/16 02:39 PM
03/18/16 02:39 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I want to follow this thread because I need to build a fresh engine for my '87 D100. I thought I was going with the LA 360 core motor that I was tearing down, but yesterday discovered two DEEP long grooves in one cylinder and I doubt that block will clean up even at .060 over since it had already been bored to .040. At least I have the 360 heads to work with and I have an original LA 318 core to explore. That could be the best solution to my needs with a 4" crank and a .030 over bore will give me 390" and should be a great cheap tow motor
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Jwilli500]
#2033926
03/18/16 05:12 PM
03/18/16 05:12 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have used the SCAT in a bunch of similar builds and they are great for the $$$ unless you want to internally balance it. Eagle cast crank and SIR rods are both pure garbage. Never used Ohio crank stuff.
[Re: Jwilli500]
#2036600
03/22/16 05:29 PM
03/22/16 05:29 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
As it says, any experience with SCAT's cast version of the 4" crank. I know they're better than Eagles stuff, I'm just a little concerned with the amount of overlap between the main and rod journal with the smaller main. It'd be going in a 318 block with approximately 9.5:1, a M.P. Hydraulic Roller Cam (380 horse Crate Motor Cam) topped with EQ Magnum heads. I'd guess H.P. in the 400-450 range and more importantly similar torque numbers. Trying to get "off the fence" with some decisions here. Thanks for any useful info guys. I have a Scat Cast Crank and whole rotating assembly in my 416 (340 block). I'm probably at 450hp or so. Ported E-brock heads, 9.7:1 compression, TTI headers, M1 single plane, XE274 solid cam. I've got about 20,000 miles on it. I cruise at down the highway at 3800-4000 rpm. I go out the road course once a year and flog it all day long. Hit about 6200 rpm at end of straights. Brian at IMM said it was fine to 500hp. And he said he's check the balancing and it's fine. So I'm running a SCAT factory internally balanced kit. All's fine here.
[Re: Jwilli500]
#2036601
03/22/16 05:32 PM
03/22/16 05:32 PM
HotRodDave
Kalispell Mt.
I internally balanced one and it needed mallory and it ended up I could have bought a steel crank about the same price. External balance and no mallory needed even with stock rods.
[Re: autoxcuda]
#2037210
03/23/16 03:44 PM
03/23/16 03:44 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Thanks again guys! Autoxcuda, that is the "experience" I was hoping for. That prebalanced kit looks pretty attractive too. My bobweight should be even less than your 340 stuff. As it says, any experience with SCAT's cast version of the 4" crank. I know they're better than Eagles stuff, I'm just a little concerned with the amount of overlap between the main and rod journal with the smaller main. It'd be going in a 318 block with approximately 9.5:1, a M.P. Hydraulic Roller Cam (380 horse Crate Motor Cam) topped with EQ Magnum heads. I'd guess H.P. in the 400-450 range and more importantly similar torque numbers. Trying to get "off the fence" with some decisions here. Thanks for any useful info guys. I have a Scat Cast Crank and whole rotating assembly in my 416 (340 block). I'm probably at 450hp or so. Ported E-brock heads, 9:1 compression, TTI headers, M1 single plane, XE274 solid cam. I've got about 20,000 miles on it. I cruise at down the highway at 3800-4000 rpm. I go out the road course once a year and flog it all day long. Hit about 6200 rpm at end of straights. Brian at IMM said it was fine to 500hp. And he said he's check the balancing and it's fine. So I'm running a SCAT factory internally balanced kit. All's fine here.
[Re: Jwilli500]
#2037254
03/23/16 04:48 PM
03/23/16 04:48 PM
autoxcuda
So Cal
Thanks again guys! Autoxcuda, that is the "experience" I was hoping for. That prebalanced kit looks pretty attractive too. My bobweight should be even less than your 340 stuff. As it says, any experience with SCAT's cast version of the 4" crank. I know they're better than Eagles stuff, I'm just a little concerned with the amount of overlap between the main and rod journal with the smaller main. It'd be going in a 318 block with approximately 9.5:1, a M.P. Hydraulic Roller Cam (380 horse Crate Motor Cam) topped with EQ Magnum heads. I'd guess H.P. in the 400-450 range and more importantly similar torque numbers. Trying to get "off the fence" with some decisions here. Thanks for any useful info guys. I have a Scat Cast Crank and whole rotating assembly in my 416 (340 block). I'm probably at 450hp or so. Ported E-brock heads, 9:1 compression, TTI headers, M1 single plane, XE274 solid cam. I've got about 20,000 miles on it. I cruise at down the highway at 3800-4000 rpm. I go out the road course once a year and flog it all day long. Hit about 6200 rpm at end of straights. Brian at IMM said it was fine to 500hp. And he said he's check the balancing and it's fine. So I'm running a SCAT factory internally balanced kit. All's fine here. I bought my SCAT kit from www.immengines.com (Brian)
[Re: Jwilli500]
#2040525
03/28/16 04:47 PM
03/28/16 04:47 PM
autoxcuda
So Cal
When I get ready to pull the trigger I'll give him a call. Do you know if he checks out all the kits he sells? I think so. Just call him and leave a message.
