Re: Re-camming a 472 Crate Hemi
[Re: RAMM]
#2032450
03/16/16 03:57 PM
03/16/16 03:57 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Before tearing it down I would check and set the valve lash on that cam first and redyno it. I raced a 1970 hemi Cuda with a cheater Racer Brown hydraulic cam and lifters with the preload set at 1/4 turn on the adjusters from zero I had treid one full turn, 1/2 turn, zero preload and one or two other settings at the races over several months and the 1/4 turn hot worked the best, I shifted that motor at 7000 RPM That was when NHRA required us to use the stock valve springs and cam specs.
[Re: B G Racing]
#2032463
03/16/16 04:21 PM
03/16/16 04:21 PM
Posts: 1,051 The Great White North
RAMM
Why stay with a hydraulic cam?
I did adjust the preload while it was on the dyno and did manage to find some power. The real issue is this cam will have very little vacuum for P/B and A/C. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#2032597
03/16/16 07:27 PM
03/16/16 07:27 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
my hemi has 112 lsa, .620/.628 lift 248@.050 and I get almost 17 inhg. Crane mechanical roller spec'd by Chase Knight... Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: RAMM]
#2032738
03/16/16 11:14 PM
03/16/16 11:14 PM
Posts: 12,210 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
At the recent Indy event, I spoke with Ken Lazzeri of ICH for awhile about my current Hemi project and asked for his recommendations on intake manifold and headers. His answers surprised me a little. It would be nice if there were more info on each of Indy's many intakes, but if it is out there, I certainly haven't found it.
Anyway, for my 540" 250* cam street Hemi, he strongly recommended the dual plane intake. He said it was good till about 6,500 RPM and that the street Hemis needed all the help they could get with torque. For a mild 540" Hemi, the last thing I thought it would need was a dual plane. But he had a table full of all of his Hemi intakes, so I don't see a reason for him to misrepresent the situation.
As to hedders, I had planned to use the 2 1/8" TTIs just to make the install a little easier. And I figured the smaller tubes wouldn't hurt the street engine's performance much if any at all. Wrong again. Ken said that any 540 Hemi would really want 2 1/2", so 2 1/8" would be a real cork. 2 1/4"s would be the bare minimum. And that any exhaust restrictions would cost real performance on these things. Fortunately, I have electric cut-outs, so I'm good there.
Indy had a wall full of TTI headers and the Hemi headers were all the same price and he had them all. So I don't see any incentive for him to say anything but the truth on this subject either.
I would be interested in anyone else's opinion on his comments. My experience is with wedges and Ken's advice flies in the face of my experience with similar sized wedges. But I bought the items that he suggested. Not from Indy because of the sales tax. But I bought what he recommended.
Master, again and still
[Re: RAMM]
#2032777
03/17/16 12:03 AM
03/17/16 12:03 AM
Posts: 5,164 CT
GTX MATT
CT
I have a buddy that has a 9.5:1 528, stock MP heads, cam is a solid flat tappet around 256 @ .050 and .560ish lift, Barton single plane intake, 4150 DP (I think a 950), 2 1/4 headers, made around 640 HP and 650 ft lbs, over 600 ft lbs from 3k and up, very flat torque curve. He originally dynoed it with the stock crate engine dual plan and it was down something like 60-70 HP.
[Re: DaveRS23]
#2032788
03/17/16 12:08 AM
03/17/16 12:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What would be your max rpm... to me.. 2 1/2 sounds big and when he said you could use all the torque you can get.. again they sound big and the collector length on the TTi headers is real short which hurts the torque.. is that a 4" collector... but I dont know all the engine specs to really say what it needs
[Re: RAMM]
#2033057
03/17/16 12:34 PM
03/17/16 12:34 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Personally, I would explore something like the edelbrock victor manifold for that application, or the stage v dual carb. My preference would be to avoid a 4500 series carb for a 470-ish cu motor that's likely going to be chugging along in overdrive with the a/c running. I would spend a little time on the heads. A basic clean-up will get them easily into the 370cfm range. Flat tappet cam with ramps as fast as you feel comfortable with for a real street car. Something like a 248/254-112. I would also verify the net rocker ratio of what you have there before you make the final decision about lobe families.
[Re: fast68plymouth]
#2033627
03/18/16 09:31 AM
03/18/16 09:31 AM
RAMM
Personally, I would explore something like the edelbrock victor manifold for that application, or the stage v dual carb. My preference would be to avoid a 4500 series carb for a 470-ish cu motor that's likely going to be chugging along in overdrive with the a/c running. I would spend a little time on the heads. A basic clean-up will get them easily into the 370cfm range. Flat tappet cam with ramps as fast as you feel comfortable with for a real street car. Something like a 248/254-112. I would also verify the net rocker ratio of what you have there before you make the final decision about lobe families. The customer is adamant about keeping it single carb. I was considering the 950 4500 Gen3 to avoid the "chugging". I will be spending some time on the heads for sure. Thankyou for the advice guys. J.Rob
[Re: RAMM]
#2033832
03/18/16 03:13 PM
03/18/16 03:13 PM
astjp2
Utah and Alaska
Getting consistent and good rocker ratio's will lend itself to getting a proper cam selected. My factory wide pads were 1.32~1.4 ratio so I actually spend the money for stageV rollers and dechilles shafts, I think that it gave a much more representation of the Crane roller spec's that I installed. Loosing that much ratio would have made my engine short on expected power. Tim
I wonder why so many people are afraid of roller cams? With the lack of good zinc ratio oils and the number of flat tappet cam failures, I am surprised that more don't go for the roller deal...
