Re: Alcohol carb users ?
[Re: WILD BILL]
#2031870
03/15/16 08:44 PM
03/15/16 08:44 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lean-out valve is almost a must. Nothing fancy just a rubber line off the carb or intake and run it to a 1/2 inch ball valve mounted by the shifter. Either remove the carb before storing for the Winter (remove bowls and spray out with Seafoam) or do a quick maintenance rebuild before the next race season. When its cold on first fire-up of the day I dump a small amount of pump gas down the carb to help start up. I race almost every week from March to the middle of November so I do nothing week to week. At 135 dollars a barrel this year its one of the best things I've ever done. Make a pass, turn off the water pump and fan, open the lean-out valve to build heat while driving back to the trailer.
[Re: BigFish69]
#2031885
03/15/16 09:14 PM
03/15/16 09:14 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
I've used a lean out and pan heater but now I prefer a primer plus. I built my own but you can buy them killerrons.com. You can start and idle around on gas then switch over to alcohol. It saves a bunch of alky and starts easy even in cold weather on the gas.
[Re: BigFish69]
#2031918
03/15/16 10:06 PM
03/15/16 10:06 PM
Posts: 76 georgia
intenseneon
georgia
After I'm done for the day I let the engine get up to 180-190 degrees, and take off any breathers on valve covers to burn off any condensation.
69 Dart
