Best sealing Trans pan Gasket for race car?
#2030577
03/13/16 10:34 PM
03/13/16 10:34 PM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
727 and 904, which Gasket do you like?
Re: Best sealing Trans pan for race car?
[Re: Streetwize]
#2030629
03/13/16 11:14 PM
03/13/16 11:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is that the black plastic gasket with the double ( super thin) o ring type perimeter seal? They work [censored] with cast aluminum pans, I have that one on my 727 but it doesnt seal with the deep 904 mopar steel pan.
Whats the part number for the grey ribbed steel reinforced silicone gasket? Do they still make that one? I just use the cheapo cork gasket.. it dont leak with the cast pan.. I just use the stock cast pan on the 518(727) but its deep ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Streetwize]
#2031020
03/14/16 04:47 PM
03/14/16 04:47 PM
MR_P_BODY
On the 518 I just put together and is in the car now is the factory 518 steel pan.. its a deep one and I believe is the same as the truck pan.. it comes stock on them EDIT No P/N other than the junk yard
[Re: roadhazard]
#2031291
03/14/16 11:38 PM
03/14/16 11:38 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Only experience is with the 727 Can't beat a cast pan with machined surfaces ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This one's a TCI Greg is that a Superformance gasket on that 727 pan? I couldn't remember if I asked you if you make those or not? I need to upgrade my deep steel pan to a cast aluminum pan, it seems to leak no matter what I try.
[Re: ProSport]
#2031392
03/15/16 01:16 AM
03/15/16 01:16 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Only experience is with the 727 Can't beat a cast pan with machined surfaces ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This one's a TCI Greg is that a Superformance gasket on that 727 pan? I couldn't remember if I asked you if you make those or not? I need to upgrade my deep steel pan to a cast aluminum pan, it seems to leak no matter what I try. I forgot to get a SUPERPERFORMANCE trans pan gasket ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif)
[Re: hemi-itis]
#2031495
03/15/16 09:42 AM
03/15/16 09:42 AM
Posts: 19,665 north of coder
moparx
Only experience is with the 727 Can't beat a cast pan with machined surfaces ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This one's a TCI Greg is that a Superformance gasket on that 727 pan? I couldn't remember if I asked you if you make those or not? I need to upgrade my deep steel pan to a cast aluminum pan, it seems to leak no matter what I try. I forgot to get a SUPERPERFORMANCE trans pan gasket he said in the other thread he didn't make trans pan gaskets at this time, so maybe a prototype for testing purposes ? ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2031598
03/15/16 12:31 PM
03/15/16 12:31 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Only experience is with the 727 Can't beat a cast pan with machined surfaces ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) This one's a TCI Greg is that a Superformance gasket on that 727 pan? I couldn't remember if I asked you if you make those or not? I need to upgrade my deep steel pan to a cast aluminum pan, it seems to leak no matter what I try. I forgot to get a SUPERPERFORMANCE trans pan gasket he said in the other thread he didn't make trans pan gaskets at this time, so maybe a prototype for testing purposes ? The gasket pictured is prototype #3 ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) #2 is on my charger with the stock steel pan and seems to be working very well. #1 was destined for the Barracuda but ended up on a fellow racers NSS Coronet who was in panic mode trying to seal his pan. Believe he was using the MP deep pan and I'll have to ask if there are any puddles under his car, been a few years since he installed it. The newer style over-molded carrier type gaskets are a nice concept however, the only sealing contact are the thin raised beads. A gasket made of quality material has way more sealing surface area. JMO I would like to make these along with many other products but it's hard enough to keep up with what's going out the door now ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
[Re: moparx]
#2031603
03/15/16 12:41 PM
03/15/16 12:41 PM
Streetwize
Weddington, N.C.
If Superformance wants to send me enough to make a pan gasket..... "I'm your Huckleberry!"
I'll bet most MP steel pans leak between the middle 2 front holes, I'm thinking about just making a 1/4" thick steel bar "straddle Plate" and use longer bolts. If it has the slightest bow it's a clamping issue.
[Re: Streetwize]
#2031675
03/15/16 02:40 PM
03/15/16 02:40 PM
Posts: 14 Milford MI
grossey
Milford MI
If you want to go to the dealership and try and get the trans pan that DVW is talking about I think this is a part # that will work. 52118780AD with gasket 02464324AC. These #'s are for a 46RE but I am almost positive it shares the same shape as the 727/518 trans. But like Mr P-Body said, junkyard will probably be easier and cheaper than going the dealership route. Grossey
