Best sealing Trans pan Gasket for race car? #2030577
03/13/16 10:34 PM
03/13/16 10:34 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
727 and 904, which Gasket do you like?
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030581
03/13/16 10:37 PM
03/13/16 10:37 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
summit aluminum leaked when my dad had the car....and that was with the Mopar gasket. Swapped it to a deep 48RE pan and problem solved... Either way, love the mopar gasket!
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030591
03/13/16 10:43 PM
03/13/16 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 500 for a 904 or 518 for a 727 pans
wave
Re: Best sealing Trans pan for race car? [Re: MR_P_BODY] #2030601
03/13/16 10:49 PM
03/13/16 10:49 PM
Weddington, N.C.
Weddington, N.C.
Is that the black plastic gasket with the double ( super thin) o ring type perimeter seal? They work [censored] with cast aluminum pans, I have that one on my 727 but it doesnt seal with the deep 904 mopar steel pan.
Whats the part number for the grey ribbed steel reinforced silicone gasket? Do they still make that one?
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030606
03/13/16 10:52 PM
03/13/16 10:52 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and I've had the pan off my truck (47RE/727 shape) several times for service etc and still have the same gasket it was born with. 125 inch lb torque. About the same with the race car swapping t-brakes, service etc.... steel stock pan, mopar gasket, even torque for the win!
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030607
03/13/16 10:52 PM
03/13/16 10:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Only experience is with the 727
Can't beat a cast pan with machined surfaces shruggy
This one's a TCI
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030627
03/13/16 11:11 PM
03/13/16 11:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have the summit pan, thick rail & a a&have reusable pan gasket. 904, dry as a bone.
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030629
03/13/16 11:14 PM
03/13/16 11:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use the cheapo cork gasket.. it dont leak
with the cast pan.. I just use the stock cast
pan on the 518(727) but its deep
wave
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030675
03/14/16 12:12 AM
03/14/16 12:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Factory truck pan. They're 1" deeper than the deep pans. Stock reusable gasket. I've had mine off and on for 3 years , no leak.
Doug
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030692
03/14/16 12:51 AM
03/14/16 12:51 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
B&M pan after removing the MOPAR chrome deep pan shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Best sealing Trans pan for race car? [Re: hemi-itis] #2030947
03/14/16 03:10 PM
03/14/16 03:10 PM
Weddington, N.C.
Weddington, N.C.
Yeah the MP deep pan isn't exactly flat, might have to belt sand it like I do with them Chinese Fab aluminum Valve covers.
It only seems to drip with the Mopar 'o ring reuseable ' gasket in the very front (where the gasket is for some reason much thinner).
Theres not a huge selection of Cast Alum pans for the 904, not like the 727. It shouldn't cost $150 of new parts to stop a leak, you wouldn't think, lol.
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2030948
03/14/16 03:11 PM
03/14/16 03:11 PM
Weddington, N.C.
Weddington, N.C.
DVW ,do you have a part number for the factory truck pan?
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031020
03/14/16 04:47 PM
03/14/16 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the 518 I just put together and is in the
car now is the factory 518 steel pan.. its a
deep one and I believe is the same as the truck
pan.. it comes stock on them
EDIT
No P/N other than the junk yard
wave
Re: Best sealing Trans pan for race car? [Re: roadhazard] #2031291
03/14/16 11:38 PM
03/14/16 11:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
This one's a TCI
Greg is that a Superformance gasket on that 727 pan? I couldn't remember if I asked you if you make those or not? I need to upgrade my deep steel pan to a cast aluminum pan, it seems to leak no matter what I try.
Re: Best sealing Trans pan for race car? [Re: ProSport] #2031392
03/15/16 01:16 AM
03/15/16 01:16 AM
hemi-itis Offline
hemi-itis  Offline
This one's a TCI
I forgot to get a SUPERPERFORMANCE trans pan gasket shock
Re: Best sealing Trans pan for race car? [Re: hemi-itis] #2031495
03/15/16 09:42 AM
03/15/16 09:42 AM
moparx Offline
moparx  Offline
This one's a TCI
he said in the other thread he didn't make trans pan gaskets at this time, so maybe a prototype for testing purposes ?
beer
Re: Best sealing Trans pan for race car? [Re: moparx] #2031598
03/15/16 12:31 PM
03/15/16 12:31 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
This one's a TCI
beer
The gasket pictured is prototype #3 grin
#2 is on my charger with the stock steel pan and seems to be working very well. #1 was destined for the Barracuda but ended up on a fellow racers NSS Coronet who was in panic mode trying to seal his pan. Believe he was using the MP deep pan and I'll have to ask if there are any puddles under his car, been a few years since he installed it.
The newer style over-molded carrier type gaskets are a nice concept however, the only sealing contact are the thin raised beads. A gasket made of quality material has way more sealing surface area. JMO
I would like to make these along with many other products but it's hard enough to keep up with what's going out the door now runaway
Re: Best sealing Trans pan for race car? [Re: moparx] #2031603
03/15/16 12:41 PM
03/15/16 12:41 PM
Weddington, N.C.
Weddington, N.C.
If Superformance wants to send me enough to make a pan gasket..... "I'm your Huckleberry!"
I'll bet most MP steel pans leak between the middle 2 front holes, I'm thinking about just making a 1/4" thick steel bar "straddle Plate" and use longer bolts. If it has the slightest bow it's a clamping issue.
WIZE
In Car:
Re: Best sealing Trans pan for race car? [Re: Streetwize] #2031675
03/15/16 02:40 PM
03/15/16 02:40 PM
Milford MI
grossey Offline
grossey  Offline
Milford MI
If you want to go to the dealership and try and get the trans pan that DVW is talking about I think this is a part # that will work. 52118780AD with gasket 02464324AC. These #'s are for a 46RE but I am almost positive it shares the same shape as the 727/518 trans. But like Mr P-Body said, junkyard will probably be easier and cheaper than going the dealership route.
Grossey
Re: Best sealing Trans pan for race car? [Re: grossey] #2031747
03/15/16 04:26 PM
03/15/16 04:26 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I'm having good luck with the Moroso gasket:
Moroso 727 gasket
1979 AMC Spirit, NHRA Q/SA
