360 build with 88 block #2030655
03/13/16 11:41 PM
03/13/16 11:41 PM
LI, new york
gmachinedart1 Offline OP
LI, new york
Im in the market for an un bored 360 block for a build. I purchased a 72 block used but it had been sleeved and had other issues. I have come across an 88 roller lifter block(non magnum) and was wondering if it can be used with all the early stuff I have already purchased (camshaft, etc). The build will utilize w2 heads and solid flat tappet. I know the 88 block uses a roller lifter but still cylinder head/rocker shaft oiling. I just wasnt sure if there were any other differences related to the camshaft and lifter set up that may be an issue.
thanks
justin
Re: 360 build with 88 block [Re: gmachinedart1] #2030801
03/14/16 10:54 AM
03/14/16 10:54 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
PM sent
Re: 360 build with 88 block [Re: gmachinedart1] #2030878
03/14/16 01:31 PM
03/14/16 01:31 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah you can use the 88 block without issue in place of the 72 block. Will still take early heads (oil through rocker shafts), and all other standard stuff.
Not sure what your overall goals are... but I still even run the factory hydraulic roller lifters in mine. Holds fine to 6500 RPM where I run it to.
With a 1/2 fill and girdle mine makes a touch over 800hp with the turbo on the '90 block and cast crank.
Re: 360 build with 88 block [Re: dizuster] #2031267
03/14/16 11:14 PM
03/14/16 11:14 PM
LI, new york
LI, new york
Wow, thats some good horsepower. My plans are to use for recreational road race track days with w2 and solid flat tappet. Ryan/shady did some wotk on the heads and spec'd the cam for me, now I just need to put a shrt block together.
thanks
justin
