Page 2 of 4 1 2 3 4
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2031600
03/15/16 11:39 AM
03/15/16 11:39 AM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
What kind of valve spring pressures and what rockers?
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2031621
03/15/16 12:16 PM
03/15/16 12:16 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
T&D paired rocker, 1.75 ratio
Springs are Manley 221425 2.00" 340 seat 837lbs open, 1.150 coil bind and we are .050 from coil bind with .024 lash
Here is a pic of the pan, it has 4 drain backs, 2 on each head (front & back).
The 1# main cap cross bolt hit the oil pump so I had to cut it off.
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2031636
03/15/16 12:50 PM
03/15/16 12:50 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Very Nice!
72 Plymouth Roadrunner 11.08@123.25
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2031770
03/15/16 04:04 PM
03/15/16 04:04 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Wow.... just wow!!
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2031843
03/15/16 06:48 PM
03/15/16 06:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That should get it done............good work........
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2032000
03/15/16 10:49 PM
03/15/16 10:49 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
looks amazing
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2032175
03/16/16 04:30 AM
03/16/16 04:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2032712
03/16/16 09:36 PM
03/16/16 09:36 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice motor Wade.
Re: 572 B1 NOS Drag Week motor pictures [Re: HardcoreB] #2032766
03/16/16 10:56 PM
03/16/16 10:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Given the HP level on spray, I'm surprised the pistons didn't have all those machined corners blended & radiused before being coated.
Re: 572 B1 NOS Drag Week motor pictures [Re: Plumb Wired] #2033478
03/17/16 10:24 PM
03/17/16 10:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Originally Posted By Plumb Wired
Originally Posted By Al_Alguire
Moroso's custom shop does the covers.
Al, how do you order from their custom shop? I need a set of B1 & W8 valve covers.
Someone has been dragging his feet with billet rocker covers whistling
Alan Jones
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2033583
03/18/16 01:43 AM
03/18/16 01:43 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
first time iv seen studs on side of block instead of bolts, was that a special order ?
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2033585
03/18/16 01:51 AM
03/18/16 01:51 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Studs come with a World block....
Re: 572 B1 NOS Drag Week motor pictures [Re: BradH] #2033637
03/18/16 08:58 AM
03/18/16 08:58 AM
Tulsa, Ok
Tulsa, Ok
There are no sharp edges on the Pistons, they did slightly radius them but they could have been a little more aggressive.
Here is a picture of the nitrous softening Bucks did to the chambers. (I have to go and touch them up because we had to surface them for a small scratch from when we machines the pads down for the T&D rockers.)
Re: 572 B1 NOS Drag Week motor pictures [Re: LA360] #2033649
03/18/16 09:38 AM
03/18/16 09:38 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Alan, not throwing stones at you specifically but this is what is really getting on my nerves anymore. It takes forever to get anything done. Chassis shops, engine/machine shop and paint & body guys are the worst. lol spank
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: 572 B1 NOS Drag Week motor pictures [Re: Plumb Wired] #2034330
03/19/16 08:03 AM
03/19/16 08:03 AM
LA360 Offline
LA360  Offline
I hear where you're coming from Mike, my friend who bought the orange Dart from over your way is having the same problem. Put his car to have some chassis work done, was told it'd be done in 3 weeks. 5 weeks later, still hasn't been started.
As for the Rocker covers, been bogged down with my divorce. I'll have something done by June
Sorry for the hijack!
Alan Jones
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2034471
03/19/16 01:05 PM
03/19/16 01:05 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Is the "softening" that 'semi-hemi" cut on the opposite side from the spark plug? I have a set of B1s that have been milled to 47cc chamber and that "semi hemi" cut would go a long way to making the chambers larger.
Edit: I looked at my 47cc chamber heads and they have been surfaced all the way to the edge of the 2.44 intake valve seat. No room to "semi hemi" left.
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2034496
03/19/16 01:52 PM
03/19/16 01:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That looks like a big scoop cut in that pic......but it's not. Usually it's only about 2 CCs in the taper cut. So no, just "softening" the chamber in your 47CC heads isn't doing much
Re: 572 B1 NOS Drag Week motor pictures [Re: Monte_Smith] #2034896
03/20/16 08:03 AM
03/20/16 08:03 AM
moparx Offline
moparx  Offline
is my eyesight getting that bad, or does it appear from the pic there seems to be chatter marks on the valve heads ? if it is just the shadows of the pic, ok. but if it is chatter, what is it's purpose ? can you catch it with your finger nail ?
beer
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2136747
08/19/16 05:13 PM
08/19/16 05:13 PM
Tulsa, Ok
Tulsa, Ok
Finally finished this one and got it on the Dyno.
I was hoping for 800-850hp but expecting just 800 so I and my customer were very pleased with the 904hp number.
This was with 91 pump gas that I picked up at the Quick-Stop on the way to the dyno.
The header gaskets we used were hanging into the exhaust ports close to 1/4" all the way around, the headers were some that were just given to me and have mufflers on them so there were a few more HP left on the table.
I'd like to publicly thank Monte for helping me design of several aspects of the motor (and of course the awesome work on plumbing the intake).
I'm not a nitrous guys so my work is done with it but it's build and designed to handle an additional 800+ HP of giggle juice.
Dyno Sheet
Re: 572 B1 NOS Drag Week motor pictures [Re: WadeMetzinger] #2136773
08/19/16 06:06 PM
08/19/16 06:06 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice numbers, but....... You ran it without any crank case breathers?
Page 2 of 4 1 2 3 4
