1969 Super Bee, correct heater hose bracket screw/bolt?? #2030821
03/14/16 11:33 AM
03/14/16 11:33 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I am putting the final touches on my '69 Super Bee. Is this the correct screw/bolt that holds the heater hose bracket on the RH inner fender?
If not, does anyone have a picture of the correct one?
Thanks!
Stan
Re: 1969 Super Bee, correct heater hose bracket screw/bolt?? [Re: HemiStan] #2030833
03/14/16 12:00 PM
03/14/16 12:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bolt
Re: 1969 Super Bee, correct heater hose bracket screw/bolt?? [Re: 62maxwgn] #2030888
03/14/16 01:44 PM
03/14/16 01:44 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
62maxwgn,
Thanks! That looks like a bolt with a head that has an integral one-piece washer, not a captured washer like the one in my picture. Is that correct?
Thanks.
Stan
Re: 1969 Super Bee, correct heater hose bracket screw/bolt?? [Re: HemiStan] #2031138
03/14/16 07:54 PM
03/14/16 07:54 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
this bolt you are looking for is the same as the ballast, and starter relay and other items. it has the captured washer as you said. and most I have removed have no head markings.
HEMI,S ARE FOREVER!!!
Re: 1969 Super Bee, correct heater hose bracket screw/bolt?? [Re: HemiStan] #2031582
03/15/16 12:00 PM
03/15/16 12:00 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
The above guys are pretty much correct.
I have pictures of three different bolts used on the inner fender bracket, all on original unrestored 69 cars. Two styles had a built in flange and the lone one had a loose washer-but not like the one you have pictured.
Re: 1969 Super Bee, correct heater hose bracket screw/bolt?? [Re: Paul Jacobs] #2031634
03/15/16 01:48 PM
03/15/16 01:48 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thank you for the info everyone! That helps alot. I got it mounted yesterday along with the heater hoses.
Stan
