E Body speedometer needle
#2030341
03/13/16 05:02 PM
03/13/16 05:02 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
The speedo needle broke on one of my 70 cudas. I see you can buy a new one. anyone ever chance one? any tips?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: E Body speedometer needle
[Re: Old School]
#2030423
03/13/16 07:20 PM
03/13/16 07:20 PM
Old School
Virginia Beach, VA
Thanks Mike! So I do not need to remove the spedo from the car?
[Re: Old School]
#2030431
03/13/16 07:26 PM
03/13/16 07:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks Mike! So I do not need to remove the spedo from the car? You can do it "in car", you'll need to remove most of the dash/instrument fascia panels to get down to the clear plastic lens for removal,the speedo can stay in the cluster, a pair of thin needle nose pliers with a 90 degree turn to the tips will help in holding the speedo pin stem steady while R&R'ing of the needle
[Re: second 70]
#2031578
03/15/16 11:52 AM
03/15/16 11:52 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Mine broke 38 years ago. None of the gears or anything else in the chain were cracked or damaged. Just the pointer broken. Drove it 20+ years that way with the pointer still on the bottom of the speedo. Finally opened it up to repair the trip odometer and while it was open I repaired it by super gluing a small strand of copper wire in the v channel of the pointer joining it up. I painted it with Coast Guard Orange model paint. Has been 5 years since the repair and it is still holding up. The damage can also be caused by a foreign object getting into the magnetic drive at the rear of the speedometer. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2031606
03/15/16 12:45 PM
03/15/16 12:45 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Mine broke 38 years ago. None of the gears or anything else in the chain were cracked or damaged. Just the pointer broken. Drove it 20+ years that way with the pointer still on the bottom of the speedo. Finally opened it up to repair the trip odometer and while it was open I repaired it by super gluing a small strand of copper wire in the v channel of the pointer joining it up. I painted it with Coast Guard Orange model paint. Has been 5 years since the repair and it is still holding up. The damage can also be caused by a foreign object getting into the magnetic drive at the rear of the speedometer. Craig Interesting. I fixed one the same way many years ago but instead of copper wire I went to fabric store and bought the smallest size sewing machine needle they make. Extremely thin/stiff/light. Superglue and Testor's fluorescent orange paint. Worked fine
[Re: DAYCLONA]
#2670955
06/28/19 12:02 AM
06/28/19 12:02 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
Thanks Mike! So I do not need to remove the spedo from the car? You can do it "in car", you'll need to remove most of the dash/instrument fascia panels to get down to the clear plastic lens for removal,the speedo can stay in the cluster, a pair of thin needle nose pliers with a 90 degree turn to the tips will help in holding the speedo pin stem steady while R&R'ing of the needle This may be possible, but there is enough disassembly required to get to the point of being able to remove the clear plastic lens that you might as well make it easy on yourself and just pull the entire gauge cluster out so that you can work on the thing on a bench or table "like a gentleman".
