Page 1 of 4 1 2 3 4
Pick a cam for the Imperial #2030415
03/13/16 07:08 PM
03/13/16 07:08 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The big Imp is going to need a new cam. Which one fits the bill the best?
440
Advertised 8.2:1 compression. Real world says 7.8 is more realistic.
Edelbrock heads
Stock intake
650 AFB carb
Stock manifolds
Dual 2-1/4" exhaust
727
Stock large converter
Power brakes
3.23 gear
29" tires
5100+ lbs
This car is a big lumbering highway cruiser. It needs power between 2200 and 4500 rpm.
The recently deceased cam was a Comp 21-000-5 single pattern cam. 261 degrees (218 @ .050) and .463 lift with 114 degrees of separation.
It might have been a slight improvement over stock but it was still a gutless pig.
- Stu Harmon
Re: Pick a cam for the Imperial [Re: feets] #2030418
03/13/16 07:11 PM
03/13/16 07:11 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
These Hughes "whiplash" cams are made for low compression engines with 9.2 comp or less.
http://www.hughesengines.com/Index/produ...mp;partid=30173
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Pick a cam for the Imperial [Re: 19swinger70] #2030434
03/13/16 07:32 PM
03/13/16 07:32 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Nice until this one little bit:
Your vacuum should be in the 9"-11" range using this cam.
That does not sound friendly to power brakes and vacuum actuated AC.
- Stu Harmon
Re: Pick a cam for the Imperial [Re: feets] #2030447
03/13/16 07:40 PM
03/13/16 07:40 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would do a 112 lsa to keep the vacuum up, 230-240@.050 and a .560-.600 lift The wider LSA will also help with dynamic compression. Chase Knight spec'd my Hemi cam, I was looking for similar performance. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Pick a cam for the Imperial [Re: feets] #2030474
03/13/16 08:21 PM
03/13/16 08:21 PM
GA
baracus Offline
baracus  Offline
GA
Agree on the 112 lsa, too much duration for his intended use.
Re: Pick a cam for the Imperial [Re: feets] #2030476
03/13/16 08:23 PM
03/13/16 08:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
mopar 272-.455
Re: Pick a cam for the Imperial [Re: feets] #2030491
03/13/16 08:50 PM
03/13/16 08:50 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
The converter, compression, gears, and weight all work against you and that "gutless pig" feel. I'd suggest contacting a few converter companies PTC, Continental, Coan.. Ect and work closely with a them and a cam grinder as a team to liven he car up. I'd also suggest you strongly consider moving lower (numerically higher) gears. 3.73 would be a fair compromise. Your best hope at a satisfactory result will come from using torque multiplication in your favor rather than seeking a camshaft alone as the fix. There's no point in suggesting a cam because the 218@.050 wasn't a bad choice build a package
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Pick a cam for the Imperial [Re: R70RUNNER] #2030499
03/13/16 08:59 PM
03/13/16 08:59 PM
Kirkland, Washington
Pacnorthcuda Offline
He's already stated its a "highway cruiser"
It would no longer fit that description with 3.73's.
Re: Pick a cam for the Imperial [Re: feets] #2030503
03/13/16 09:08 PM
03/13/16 09:08 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
a 29" tire??
i would try this cam...
http://www.manciniracing.com/vohydcamkitc7.html
and maybe put some shorty headers on it.
Re: Pick a cam for the Imperial [Re: feets] #2030543
03/13/16 10:01 PM
03/13/16 10:01 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
No to headers, I would also look to doing a stroker crank, if you are going through the headache of a cam, why not a crank too? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Pick a cam for the Imperial [Re: feets] #2030555
03/13/16 10:14 PM
03/13/16 10:14 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No to the stroker. If I want big power I'll slide the turbos under the hood. This car is supposed to be all about trouble free cruising. It would be nice to have a little more power for the enthusiastic moments and getting around traffic.
- Stu Harmon
Re: Pick a cam for the Imperial [Re: feets] #2030565
03/13/16 10:25 PM
03/13/16 10:25 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Is this a rebuild or just a cam swap? I would use cam designed for a large truck with big tires...trucks weight upwards of 7~8K and with 35" tires they are dogs, a cam with wide LSA, high lift and short to moderate duration is what I did on my 78 powerwagon. Upping compressions to 9.5-10 to 1 would also help, longest runners on the intake you can get also makes a difference in your cruising experience. I saw someone in Idaho put a long ram intake on their 440 and it ran out of steam at about 4k rpms but was a beast up to that point. None of these options require a turbo or massive changes (except the intake) also a good tune and distributor curve matched to what rpms your engine is built to run. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Pick a cam for the Imperial [Re: feets] #2030584
03/13/16 10:39 PM
03/13/16 10:39 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Just a cam swap, assuming the rest of the bits survived.
I don't recall the piston height but I think they were somewhere around .125" deep.
- Stu Harmon
Re: Pick a cam for the Imperial [Re: feets] #2030612
03/13/16 11:00 PM
03/13/16 11:00 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
RPM intake + MP .528 cam, or call Duane Porter and get advise from someone that KNOWS what they are doing. twocents BTW, I'm getting 15"(N) @ 1000 rpm with a baby Thumpr cam in a lowish CR(9.6:1) stock stroke 400 with a tunnel ram. work I've got a Crane 302 cam I'll let go cheap- never run. 232/242@ .050 112 LSA.
Re: Pick a cam for the Imperial [Re: feets] #2030630
03/13/16 11:15 PM
03/13/16 11:15 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
That's why I said "strongly consider" the gears....in my experience 3.23's are not really cruising gears. It's a crap ratio. Too low to cruise to high to be a performance gear. It's a lousy "on the fence ratio."
3.23= 28"@65mph is 2600rpm..3.73 would still be under 3,000rpm.
We want it all with as few concessions as possible...there's limited compression as it is. Frankly if it were mine I'd go smaller than the previous 218 cam, Maybe even sub 210... No bigger than 214@.050. The two smallest voodoo cams might fit the bill for me, how I'd do it...As I said before, OP I wouldn't buy a cam with out speaking to a converter company because IMHO that's where your power is hiding(in the converter). Once I had that info and some guidelines from them id look around and speak with cam companies. You can throw a cam at it and hope for the best.. But I believe that was what was previously done. With the proper multiplication of torque through a better package you should get where your trying to go.
Re: Pick a cam for the Imperial [Re: feets] #2030649
03/13/16 11:32 PM
03/13/16 11:32 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
3/4 race cam, to go with your 3/4 of a cam gear.
biggrin
Re: Pick a cam for the Imperial [Re: feets] #2030704
03/14/16 01:09 AM
03/14/16 01:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
troll
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Pick a cam for the Imperial [Re: feets] #2030724
03/14/16 01:42 AM
03/14/16 01:42 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Aluminum heads and not taking advantage of them? realcrazy Sell them and do an RV porting job on a set of closed chambered iron models. Maybe even some 516's :stir: 2500 stall would help. My Maxivan with the 360 was running a 2200 cheapy generic converter, Comp 252* RVcam with 3:21's and was a 6000lb shoe box. I ran a 800TQ or a Mopar '86 model Qjet on an Offy Dual Port intake.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Pick a cam for the Imperial [Re: feets] #2030731
03/14/16 01:55 AM
03/14/16 01:55 AM
Rug_Trucker Offline
Rug_Trucker  Offline
Grab some C body HP manifolds. Believe it or not the Holley SD would be a great intake! Even with the 650.
Re: Pick a cam for the Imperial [Re: feets] #2030807
03/14/16 11:15 AM
03/14/16 11:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran Summits small cam in one of my Imps.Had nice manners and even with almost 200K on the speedo had power and good gas mileage at around 15 or so average.Rocky
Chrysler Firepower
Page 1 of 4 1 2 3 4
