My understanding after a lot of research is,
Duplicating the factory spot welds on older vehicles is all but impossible. one can get the "puddle" but the integrity of the joint may not be there. The newer "body shop" machines are typically designed for thinner metals. Throw in the access issue, IE: getting to difficult areas and getting adequate heat and penetration only Muddy's the waters.
The equipment used on the line was running off industrial amperage / voltage and the individual welders at each station were designed to do a specific job.
Achieving the "look" is one thing, achieving the structural integrity is another.
my research indicated that one is better off structurally to use a mig or tig and do plug welds,
hope this helps
![popcorn popcorn](/ubbthreads/images/graemlins/custom/popcorn.gif)
