Page 4 of 20 1 2 3 4 5 6 19 20
Re: Moparts official power adder thread [Re: furious70] #2028351
03/10/16 04:41 AM
03/10/16 04:41 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Who designs this stuff?
Re: Moparts official power adder thread [Re: Jeremiah] #2028353
03/10/16 05:01 AM
03/10/16 05:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A 45* fitting will do wonders... but if you
didnt use that throttle cable set up it would
fit.. I use that same one
EDIT
My bowl entries are on the pass side of the carb..
you might want to swap the bowls end for end to
get them on the pass side...... never mind...
I see thats for a regulator or a solenoid
wave
Re: Moparts official power adder thread [Re: an8sec70cuda] #2028380
03/10/16 10:02 AM
03/10/16 10:02 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Originally Posted By an8sec70cuda
Ian...my D/A shocks are a little shorter than my old shocks so I lost about an inch of travel. Between that and tightening up the extension I was able to get the car to leave VERY nicely last time out. Came up about a foot and carried it about 100 feet out.
very good mate that about my limit on hooking ,you are doing a great job cheers mate.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Moparts official power adder thread [Re: MR_P_BODY] #2028466
03/10/16 12:44 PM
03/10/16 12:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
EDIT
wave
A 45* will work, but if the designer took five minutes to test fit the bracket it could have been made to work with any fitting. Instead I have another $100 worth of junk on the shelf on my shop.
Re: Moparts official power adder thread [Re: Jeremiah] #2028473
03/10/16 12:54 PM
03/10/16 12:54 PM
an8sec70cuda Offline
Jeremiah...that's why I like these brackets.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: birdtracker] #2028478
03/10/16 12:57 PM
03/10/16 12:57 PM
Originally Posted By birdtracker
thanks for the advice. My motor is 14 1/2 already. Birdtracker
Nothing wrong w/ spraying a motor with that much compression, you just need to be conservative w/ timing. I've recently started spraying a 14.5:1 sb chevy. We'll see how it goes.
CHIP
Re: Moparts official power adder thread [Re: tboomer] #2028823
03/10/16 10:12 PM
03/10/16 10:12 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Timing is everything.
Cold air is better than warm air.
Don't use exhaust gaskets on turbo cars.
Small compressors cause higher back pressure than large ones.
Transmissions don't like turbos.
Use the strongest wrist pins you can get.
More head bolts are better than less head bolts.
It's better to spend big money on engine management for a junk engine, than it is to put junk controls on an expensive engine.
Oh... and timing is real important too.
Re: Moparts official power adder thread [Re: TRENDZ] #2028844
03/10/16 10:35 PM
03/10/16 10:35 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
LOL
Re: Moparts official power adder thread [Re: TRENDZ] #2028898
03/11/16 12:13 AM
03/11/16 12:13 AM
birdtracker Offline
birdtracker  Offline
so on exhaust flanges just use high temp gasket maker?
Birdtracker
Re: Moparts official power adder thread [Re: tboomer] #2028905
03/11/16 12:22 AM
03/11/16 12:22 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Yes, some of the high temp silicone sealants are the trick, I use that on my nitrous mill
Re: Moparts official power adder thread [Re: an8sec70cuda] #2028907
03/11/16 12:23 AM
03/11/16 12:23 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
No no no.... you need a fogger!!!
Re: Moparts official power adder thread [Re: tboomer] #2028912
03/11/16 12:38 AM
03/11/16 12:38 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use ultra copper on turbo my headers.
Re: Moparts official power adder thread [Re: FastmOp] #2028989
03/11/16 02:54 AM
03/11/16 02:54 AM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
I SAID I WAS'NT THE SMARTEST GUY,BUT WHAT ABOUT THIS. every time you post,whether it's a new post or a reply to an existing post. start the post off with the POWER ADDER IN CAPITAL LETTERS. TURBO,N2O,BLOWER, SUPERCHARGER, something that will alert everyone what this post topic is about. just trying to find a way to sort thru this faster.
Re: Moparts official power adder thread [Re: Jeremiah] #2029268
03/11/16 04:18 PM
03/11/16 04:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
EDIT
wave
It would be great if everything worked with every combination of parts you may want to use, but it doesn't always work like that. The bracket has extra clearance to also work with 50cc pumps. If the line fit, but it wouldn't clear the pump arm, guys wouldn't like that either........LOL!!
Re: Moparts official power adder thread [Re: tboomer] #2029319
03/11/16 06:09 PM
03/11/16 06:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks like if you screwed the line on it would fit.
Re: Moparts official power adder thread [Re: tboomer] #2029841
03/12/16 04:52 PM
03/12/16 04:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Does anyone run a Pro Mag 44 with EFI?
Re: Moparts official power adder thread [Re: tboomer] #2029864
03/12/16 06:08 PM
03/12/16 06:08 PM
IL
furious70 Offline
furious70  Offline
IL
for whatever reason, against conventional wisdom, my usage of oem exhaust manifold gaskets with copper rtv works. Perhaps it's because I'm using an OEM cast manifold that doesn't move around like a fabbed one likely would. I only used goo in the joint from manifold to piping, but I think I used a steel shim gasket at the turbine.
If I was running 20psi of boost and had my 2:1 backpressure maybe I'd be a lot more leaky than I am =)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Nitrous [Re: furious70] #2031542
03/15/16 11:06 AM
03/15/16 11:06 AM
I have -3 lines from my solenoids to the plate. Is it worth it to change the solenoid fittings to -4 and use the -4/-3 combo lines?
The line itself looks to be the same size, so the only gain in flow looks to be from the larger -4 fittings on the solenoids.
I know all the bigger kits use the -4/-3 lines. I started w/ a small kit and worked up to a big one. Just curious if it's worth the $140+ to change 2 fittings and 4 lines?
CHIP
Re: Nitrous [Re: tboomer] #2031557
03/15/16 11:27 AM
03/15/16 11:27 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Care to critique my set up? 360 10.5:1 compression, eddy 63cc chamber heads, MP.557 solid cam. Holley 750 DP. Edelbrock nitrous kit with 100 shot jets. -8 feeding line with a holley blue pump feeding the engine, -6 and another holley blue pump feeding the nitrous (from the same fuel cell). Rings are gapped I believe .025 (speedpro recommended for nitrous). My plugs are NGK that are gapped at .040. I haven't run it yet so I figured I post my combo and let the pros tell me if I made any mistakes. I'm also using an MSD digital 6 with the nitrous retard removing 5 degrees of timing once the WOT switch is made.
Re: Nitrous [Re: superchuck] #2031594
03/15/16 12:25 PM
03/15/16 12:25 PM
UK
rb446 Offline
rb446  Offline
UK
Hi, well I'm no pro at N20 and lots have changed since then re N20 but thats almost exactly how I ran my Cheater Kit 25years ago, except I ran my NGK's at a bit smaller gap than that with the MSD6A, both on my 340 at 250hp jets and the 440 at 175hp jets, could go as low as 4psi on the N20 fuel with a seperate blue pump.
ps. thought I was doing ok by getting 1.4sec gain on the 340 with 250hp (110/110 jets), apparently not?, I was only getting about 150hp actual fly hp gain according to the mph/weight.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
