Re: 71 GTX pinstripe
[Re: mopglen]
#2028662
03/10/16 06:11 PM
03/10/16 06:11 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
71 GTX pin stripes were painted. Gloss in sheen.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: mopglen]
#2028697
03/10/16 07:08 PM
03/10/16 07:08 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks. I still need the width. T appreciate the reply.Glen The width is approx .200, just a whisker over 3/16", as stated they were painted on, and the quality varied greatly, Trimbrite has a 3/16" wide "paint pinstripe" that has the effect of a brushed pinstripe line in it's premium pinstripe line, it's textured with a brush stroke and semi transparent micro brush lines of color, just like you'd see on a real painted pinstripe, retail is about $30 for 50 feet, I found it while doing the 71 GTX vert project mike
[Re: mopglen]
#2029133
03/11/16 12:34 PM
03/11/16 12:34 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Does the correctness of the stripe matter?
As Dayclona mentioned, the stripes were hand painted on at the factory and as such, their consistency varied considerably. The tape pin stripe will actually be much more consistent that the original stripes were. If that matters.
There are some repops of the original engineering drawings of these details floating around. I may even have some copies left over from my projects. Getting the bends around the wheel well openings right is the real test.
And any good pin stripe painter can whip them on in a few minutes. Sometimes there are pin stripe painters at car shows that do the stripes then and there.
Master, again and still
[Re: mopglen]
#2030035
03/13/16 01:02 AM
03/13/16 01:02 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thank you very much Dave. The drawing is a little hard to read. Is the stripe about 1/2 inch above the body line? Appreciate your help. Glen No, the bottom edge of the stripe is approx 1.000 (1 inch) above the lower hard edge body line the entire length, I circled the key notes in the pic Mike
