Page 3 of 3 1 2 3
Re: H Beam rods- Scat vs Molnar [Re: jcc] #2028613
03/10/16 04:09 PM
03/10/16 04:09 PM
MT-Tom Offline
MT-Tom  Offline
Rods are constantly in either tension or compression and the forces are a straight line between the center of the wrist pin bore and the journal end bore. There are very few side to side or back and forth forces.
Re: H Beam rods- Scat vs Molnar [Re: cudadoug] #2028616
03/10/16 04:11 PM
03/10/16 04:11 PM
MT-Tom Offline
MT-Tom  Offline
Doug, the link you posted is for Campbell Enterprises who is one of our dealers. Our website is www.molnartechnologies.com
Re: H Beam rods- Scat vs Molnar [Re: MT-Tom] #2028641
03/10/16 05:18 PM
03/10/16 05:18 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Are you certain? Because it is a fact the bottom of the rod moves every revolution L to R the entire distance of the stroke, granted the mass its moving is only part of the rod with the bearing, but it is the big end. In a NA motor, the only additional forces on the piston beyond inertia forces, are on an intake stroke is less then the atmospheric pressure, on compression its CR related additional forces on piston, on power stroke its cyl pressure, on exhaust its residue cyl pressure and pumping losses. Seems like there are some additional inertia forces when rod moves L to R. Has this been calculated definitively enough to be dismissed?
Bottom line, if something moves, and it has mass, there are forces involved.
Re: H Beam rods- Scat vs Molnar [Re: Hot 340] #2028650
03/10/16 05:47 PM
03/10/16 05:47 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Tom I will be calling you in the week or so. Thanks for the info wink
5.53 @ 125 1/8th on the launch control..more left in her!
Re: H Beam rods- Scat vs Molnar [Re: Eric] #2028691
03/10/16 06:58 PM
03/10/16 06:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love your stuff, Tom!
I beat on your crank and rods most every day! drive
Re: H Beam rods- Scat vs Molnar [Re: Hot 340] #2028805
03/10/16 09:39 PM
03/10/16 09:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Dan gave me the confidence to go Molnar rods and crank on my W8 build. Rods sure were smaller than my eagles in my W5.
Re: H Beam rods- Scat vs Molnar [Re: Hot 340] #2029110
03/11/16 12:00 PM
03/11/16 12:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My Dad put Molnar rods in a 416 we built last summer. Very nice looking pieces and good service.
68 Barracuda Formula S 340
Re: H Beam rods- Scat vs Molnar [Re: jcc] #2030072
03/13/16 01:55 AM
03/13/16 01:55 AM
MT-Tom Offline
MT-Tom  Offline
We looked at the forces of beam whip years ago and found it to very minimal.
Re: H Beam rods- Scat vs Molnar [Re: Hot 340] #2031032
03/14/16 04:57 PM
03/14/16 04:57 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Check availability of the different brands too, I ordered eagle rods with a summit 10% off, they showed to ship in 2 days. Date kept getting pushed back. I didn't want to lose the 10% so i waited as long as I could. After 4 months I called them to see what could be done. They checked all the brands they sell and all had 6.76 rods back ordered. I got a refund and ordered Molnar elsewhere, they came by the end of the week.
Page 3 of 3 1 2 3
