Re: Tips and Tricks for Loosening K-Member Bolts
[Re: loco340cuda]
#2027033
03/08/16 03:29 AM
03/08/16 03:29 AM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
You can get a spray can straw of PBblaster through the frame holes and squirt plenty of PBblaster on the bolts inside the frame for a few days. That did wonders for all the Kframe bolts I have removed. came out Real easy!
[Re: loco340cuda]
#2027319
03/08/16 05:51 PM
03/08/16 05:51 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I don't have an air compressor so i will have to use a breaker bar.
Can you beg/borrow a decent electric or cordless impact? And keep in mind if you hose the bolts down with flammable penetrating chemicals to be extremely careful if you end up needing to apply heat.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#2027363
03/08/16 07:03 PM
03/08/16 07:03 PM
RapidRobert
And keep in mind if you hose the bolts down with flammable penetrating chemicals to be extremely careful if you end up needing to apply heat. We wouldn't want another member in the hospital for K member issues. (I ain't sayin you ain't carefull tho!)
