Laguna Seca Exhaust 92db max
#2026463
03/07/16 02:10 PM
03/07/16 02:10 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I was going to work this morning and a police officer was waiting for me and pulled me over. He said that one of the neighbors had called in a noise complaint on my car because of the noise. I have a 3 inch X-pipe setup with Magnaflow mufflers that dump out before the axle so it is quite loud, but it's not like I rev my engine to piss off the neighbors as I am very respectful of them as well and my neighborhood is right next to a train track haha! The officer was cool and let me go but said if my neighbors complain again I will get cited. I plan on building a super quiet exhaust which is cool because now I will be able to drive at Laguna Seca with their stupid 92 decibels or less rule. Will be using 2.25 or 2.5 inch piping to keep it all light, what mufflers would you guys use? Thanks!
Re: Laguna Seca Exhaust 92db max
[Re: RylisPro]
#2026628
03/07/16 05:52 PM
03/07/16 05:52 PM
Posts: 22,727 Bitopia
jcc
Bitopia
Isn't dumping before the axle the first real problem? Maybe using what you got, and simply stepping it down to 2.25 over axle and out the back tailpipe, may do the trick, be a lot easier then starting over.
[Re: RylisPro]
#2026822
03/07/16 10:44 PM
03/07/16 10:44 PM
Posts: 107 so cal
alltime
so cal
When I run my cuda at Laguna I run 2.5" Flow Masters with turn downs in front of the rear axles. When I pass the sound booth at turn 6 I have never been black flaged for being over 92db the 4 races Ive run there.
The cop cant ticket you just because they complain again. Tell him that you have been nice an leaving the Harley at home...LOL.
The inexpensive 2.5 " Turbo mufflers are basically the same sound and at levels similar to OEM Hemi mufflers from 1970, which is way quieter than 92 Db.
Sounds like you may have to start knocking on neighbors doors at 3am and apologizing for your car, Just to let them know you are conscientious of course.
Alltime
[Re: dangina]
#2027337
03/08/16 06:21 PM
03/08/16 06:21 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I run 2.5" tubes, flowmasters, dumped in front of the axles.... great sound, less weight... local authorities have pulled me over just asking if the car is for sale!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: RylisPro]
#2027489
03/08/16 09:43 PM
03/08/16 09:43 PM
Posts: 106 Waterloo Iowa
80mirada
Waterloo Iowa
i would find out what the local ordinances are. One of my friends got a ticket in a small town one night, but the only noise ordinance for the town was "No spurring your horse in front of the tavern on Sunday morning".
[Re: 80mirada]
#2027493
03/08/16 09:47 PM
03/08/16 09:47 PM
jcc
Bitopia
But that wasn't my horse.
[Re: RylisPro]
#2028312
03/10/16 02:23 AM
03/10/16 02:23 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I run the full tti 3" exhaust with their headers on my challenger. It's quite loud when I'm on it, but when I'm trying to be respectful it isn't bad at all. Mine runs all the way out the back to tips. I think getting rid of the dump before the axle and installing tailpipes will probably make a big enough difference to keep you out of trouble. -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: Jon @ Hotchkis]
#2029151
03/11/16 12:59 PM
03/11/16 12:59 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Grab a set of 2.5" tail pipes that run as far back as possible. If those alone aren't enough you can chop out the rear section between the axle and bumper and put the longest set of glasspacks you can fit:
I've done this on a vehicle before and it really took the raspy bite and highway drone out of the system
[Re: RylisPro]
#2029207
03/11/16 02:45 PM
03/11/16 02:45 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I thought long and hard about a proper solution and decided that my neighbors can go pound sand. It took me a long time to build my car they way it is and I think its perfect no changes needed haha! I'm just going to get a daily driver beater so I don't wake people up in the morning. I called the police dept. They were cool and they said I will only get ticketed if I get caught in the act. I will only drive my car random times so no worries there!
[Re: RylisPro]
#2029271
03/11/16 04:22 PM
03/11/16 04:22 PM
jcc
Bitopia
Just make sure your exhaust issue is not a gateway to other possible violations. This post makes me wonder if a muffler needs some exit back pressure to be most effective in quieting the exhaust. Additionally, if one wanted the loudest exhaust possible, exiting underneath the car midway, likely provides the best acoustic coupling, ie loudest, kinda like how some small consumer home sub woofers are designed, with woofers facing the floor.
[Re: RylisPro]
#2029284
03/11/16 04:43 PM
03/11/16 04:43 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ive put 2.5" turndowns on 3" mufflers and it quieted it down some. A longer bodied muffler helps also, a 14" body will be quite a bit louder than an 18" bodied muffler.
Mopar to the bone!!!
[Re: RylisPro]
#2029593
03/12/16 01:45 AM
03/12/16 01:45 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
I have a healthy 451 and am using a stainless magnaflow 2 1/2" system and it's pretty loud, especially when I get on it. I'm thinking of using something at the end of the tail pipe to act as a resonator? It's not too loud in the car but behind somewhat.... not REAL loud but enough to attract attention. I figure sooner or later the police will be on my case.....
