Re: 3.9 magnum timing chain
[Re: plumcuda]
#2026565
03/07/16 04:16 PM
03/07/16 04:16 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Regular damper puller works fine. I would suggest getting one of the 3 way adjustable timing chains and advance the cam 3-4 degrees while in there, they really like it. I always pull the fan bolt off while the belt is still on, use a long wrench and smack it real good with a hammer, usually one of two smacks breaks it loose then they just spin off real easy turning the fan.
[Re: plumcuda]
#2026636
03/07/16 06:03 PM
03/07/16 06:03 PM
HotRodDave
Kalispell Mt.
I throw the tensioner in the trash and install a good chain (double roller, 3 way adjustable).
