pic of 71 challenger trunk light routing #2025053
03/05/16 02:37 PM
03/05/16 02:37 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
anyone have a pic of how to run the trunk light through the trunk lid and where the push switch mounts? thanks
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: pic of 71 challenger trunk light routing [Re: yella71] #2025124
03/05/16 04:39 PM
03/05/16 04:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
hope this helps
mike
Re: pic of 71 challenger trunk light routing [Re: yella71] #2025312
03/05/16 10:01 PM
03/05/16 10:01 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
original car,,,,
Re: pic of 71 challenger trunk light routing [Re: yella71] #2025313
03/05/16 10:01 PM
03/05/16 10:01 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Re: pic of 71 challenger trunk light routing [Re: 69CHARGERMD] #2025632
03/06/16 11:14 AM
03/06/16 11:14 AM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
Thanks , you guys are awesome. I put the light socket in but where does the switch mount? in the service manual drawing it looks like a tab on the lip of the trunk but the original car and mine have none. before my car was repaired I remember the switch right in the corner of the trunk gutter. that was not right I'm sure. The light I have has no switch in the light itself.
Re: pic of 71 challenger trunk light routing [Re: yella71] #2025635
03/06/16 11:16 AM
03/06/16 11:16 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
It's a mercury switch inside the socket.
Re: pic of 71 challenger trunk light routing [Re: HEMICUDA] #2025649
03/06/16 11:37 AM
03/06/16 11:37 AM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
the light I have has no mercury switch . it is a 2 wire socket I guess it is not the correct light but it was in the car when I got it (1987) As I said I remember a push switch (like a door jam switch) in the corner of the trunk gutter I knew that was not right. If a mercury switch light is correct I have a light from some other mop. It's a convertible if it makes a difference.
Re: pic of 71 challenger trunk light routing [Re: HEMICUDA] #2025655
03/06/16 11:49 AM
03/06/16 11:49 AM
MD
floyd Offline
floyd  Offline
MD
"Mercury switches, that's heavy s**t. I haven't seen anything like this since the war."
Re: pic of 71 challenger trunk light routing [Re: floyd] #2025674
03/06/16 12:04 PM
03/06/16 12:04 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
Mercury, switches carburetors leaded fuel no catalytic converters...OMG this car is just a environmental disaster sorry I gotta laugh.
Re: pic of 71 challenger trunk light routing [Re: yella71] #2026125
03/06/16 10:40 PM
03/06/16 10:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Re: pic of 71 challenger trunk light routing [Re: screamindriver] #2026342
03/07/16 10:00 AM
03/07/16 10:00 AM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
I'm not doubting what you guys are telling me but the plug on the light asm. in your pic is not the same as the plug on my harness that is in my car. The harness is the original harness that the car was built with. I'm sure. It has a single square spade male plug not the twin pin with a clear/white plug. like I said does it make a difference because its a ragtop? I can't find it in mt service manual.
Re: pic of 71 challenger trunk light routing [Re: yella71] #2026360
03/07/16 10:40 AM
03/07/16 10:40 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
The switch you are talking about is commonly seen on B-bodies. Maybe you are recalling another car? Any e-body light assembly I have seen has had the "switch" built into the housing. If you do not have the mercury style switch, then you have the wrong light. There is no tab on the rain gutter that I could see that would accommodate a push switch. Someone most likely added the tab on your car if you saw it there before restoration. Probably to be able to use the wrong switch.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: pic of 71 challenger trunk light routing [Re: yella71] #2026411
03/07/16 11:49 AM
03/07/16 11:49 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The factory 71 convertible pics I supplied are the same as the hardtop prints regarding the trunk wiring/light, plus the pic Colin has shown of the trunk harness/light, 2 leads pink and yellow, make sure your looking at the right ends of the harness, they are displayed in the above factory prints
mike
Re: pic of 71 challenger trunk light routing [Re: DAYCLONA] #2027691
03/09/16 01:47 AM
03/09/16 01:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The pic/PN 2947516 that Colin supplied is correct for 1970 Challenger, the 1971 Challenger pn# is 3488436, these PN# are exclusive to the E body line, I see no cross reference to other makes/models/years
hope this helps
mike
Re: pic of 71 challenger trunk light routing [Re: DAYCLONA] #2028525
03/10/16 01:07 PM
03/10/16 01:07 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
