Page 1 of 3 1 2 3
Starting from scratch which head? #2024540
03/04/16 04:17 PM
03/04/16 04:17 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Putting a 499" low deck together for the Arrow. With the CNC Indy SR's that were on it the car had gone 5.53 @ 125 with a tenth in the timer. Well...I've been thinking of trying another head possibly. Looking at the Trick Flows and the Eddy Victors. Do you folks think there is a gain or a loss to using either of these compared to the SR's?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Starting from scratch which head? [Re: Eric] #2024545
03/04/16 04:24 PM
03/04/16 04:24 PM
AndyF Offline
AndyF  Offline
MW size or Std? Also, the SR heads have a raised exhaust port so your headers might not fit if you switch to the Trick Flow heads.
The Victor heads are a nice design in theory, but execution is a bit of a mess. Biggest problem with the Victor heads is the short installed height which limits the valve spring choices and the total lift.
Re: Starting from scratch which head? [Re: Eric] #2024562
03/04/16 05:13 PM
03/04/16 05:13 PM
If you want the car to go as quick as it can with out breaking the bank then my choice would be a set of CNC ported 440-1 with a set of decent rocker arms up
Re: Starting from scratch which head? [Re: Eric] #2024576
03/04/16 05:48 PM
03/04/16 05:48 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Eric,
Time to put on the big boy pants - Indy-1 345cc CNC heads
Re: Starting from scratch which head? [Re: DoubleD] #2024597
03/04/16 06:38 PM
03/04/16 06:38 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Originally Posted By DoubleD
Eric,
iagree anything less and you may as well stay with what you have.
Re: Starting from scratch which head? [Re: Eric] #2024688
03/04/16 10:01 PM
03/04/16 10:01 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I wouldn't really call 440-1s "big boy pants". I think that would be more like B1-MCs or possibly Predators. In my opinion, unless you go to a serious head, the gains over what you have now will be little compared to money spent. Are the SRs fully ported, with Max Wedge size ports? If not, that would be a bit of a gain and require only a manifold change
Re: Starting from scratch which head? [Re: Eric] #2024721
03/04/16 11:01 PM
03/04/16 11:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You can almost buy an entire turbo setup for what a really good set of heads costs (including porting, manifold, rockers, etc.).
Boffin Emeritus
Re: Starting from scratch which head? [Re: polyspheric] #2024724
03/04/16 11:07 PM
03/04/16 11:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Ya, ya, most just jump on the power adder wagon and go fast just like they SHOULD but he`s done well n/a which personally impresses me more but it`s not about me so,.................. drive
Re: Starting from scratch which head? [Re: polyspheric] #2024732
03/04/16 11:20 PM
03/04/16 11:20 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Eric runs the Super classes with the 4 tenths tree so a turbo isn't really the way to go
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Starting from scratch which head? [Re: Eric] #2024744
03/04/16 11:40 PM
03/04/16 11:40 PM
gregsdart Offline
gregsdart  Offline
SR heads ported to MW size are short about 40 hp from a good set of 440-1 heads. If you want to go reasonably fast on a budget, my guess is 440-1 heads fully ported with 2.25 intakes and stock rockers and an easy to live with cam that won't beat them to death would be my idea of what to do. You run super classes, so ultimate power is less important to you than being able to make a lot of passes between maintainance, right?
Re: Starting from scratch which head? [Re: gregsdart] #2024748
03/04/16 11:44 PM
03/04/16 11:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's was the point. That's a lot of money spent for 40HP increase. If I was buying new castings, new rocker gear, new manifold, etc, I would want more gain than that. But that's just me
Re: Starting from scratch which head? [Re: Eric] #2024756
03/04/16 11:55 PM
03/04/16 11:55 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I wouldn't swap for the 1's either from the SR's, if the SR's aren't fully ported and max wedge intake size, I'd do that, but I think they probably are. Just not big enough difference between the two.
Re: Starting from scratch which head? [Re: Eric] #2024760
03/05/16 12:00 AM
03/05/16 12:00 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I have indy sr,s and indy 440-1cnc 345s and now putting together a set of B1s
I spent lots of money to get to the next step
it all depends on you what you could afford
looking back at what I did should have bougth the B1s
1.39 9.85 - 137 mph
Re: Starting from scratch which head? [Re: DoubleD] #2024809
03/05/16 01:48 AM
03/05/16 01:48 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Eric,
Ditto.....Probably my next purchase as well.
Re: Starting from scratch which head? [Re: Eric] #2024820
03/05/16 02:00 AM
03/05/16 02:00 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have Indy -1 345 cnc. There not worth going to. Skip them and go straight to B1s
Re: Starting from scratch which head? [Re: Eric] #2024826
03/05/16 02:12 AM
03/05/16 02:12 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The SR,s are the middle of the two other heads listed. Ported as your SR,s are, Id stay with them. Your car is light , and for the type of racing you do, is a fine head for your performance needs. My answer, no on the Victors and the Trick flows, keep what you have.
Re: Starting from scratch which head? [Re: FastmOp] #2024827
03/05/16 02:14 AM
03/05/16 02:14 AM
Colorado
506RR Offline
506RR  Offline
Colorado
In my opinion, at least go with B1 Original or M/C heads.
Or, stay with the SR heads.
Re: Starting from scratch which head? [Re: Eric] #2024835
03/05/16 02:25 AM
03/05/16 02:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Seems like allot of cabbage & work for 40 or 50 HP down
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Starting from scratch which head? [Re: gregsdart] #2024905
03/05/16 10:51 AM
03/05/16 10:51 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Eric I have a complete B1m/c package for sale and would be willing to take your SR's in on trade.
Re: Starting from scratch which head? [Re: Eric] #2024911
03/05/16 11:15 AM
03/05/16 11:15 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
Guess the other question is what are the flow numbers on the SR's? This is a good thread. I'm in the same boat with a set of fully ported ez-1's.
Page 1 of 3 1 2 3
