Re: Flexplates: 6 bolt vs. 8 bolt
[Re: @#$%&*!]
#2024762
03/05/16 12:02 AM
03/05/16 12:02 AM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I just measured my 8 bolt flexplate and the center hole measures 2.165
68 Charger R/T 440 auto
[Re: @#$%&*!]
#2026419
03/07/16 12:56 PM
03/07/16 12:56 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Does anyone know if the center hole in the 8-bolt flexplate is the same size as the 6-bolt version? I measured a 6-bolt crank flange at about 2.15" Thanks Yes they are the same , but you can't swap one for the other and use less bolts.
[Re: JohnRR]
#2027045
03/08/16 04:06 AM
03/08/16 04:06 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Does anyone know if the center hole in the 8-bolt flexplate is the same size as the 6-bolt version? I measured a 6-bolt crank flange at about 2.15" Thanks Yes they are the same , but you can't swap one for the other and use less bolts. Sure, you can just use 2 bolts, or even just 1 for a little while JUST KIDDING, so DON'T call, and DON'T write
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: @#$%&*!]
#2027046
03/08/16 04:11 AM
03/08/16 04:11 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
The 8bolt entitles you to pay more for the "hemi" parts.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: Evil Spirit]
#2032107
03/16/16 01:39 AM
03/16/16 01:39 AM
Posts: 2,782 USA
JoesMopar
USA
