What 440 rear main seal do you recommend?
#2023074
03/02/16 10:11 AM
03/02/16 10:11 AM
Posts: 1,412 E Central IN
nd65
E Central IN
Its a factory 66 440 crank and block. It has been align honed. What is the latest and greatest way to keep it from leaking? I have the Felpro gasket set, but will upgrade the rear seal based on recommendations here.
This is a street car.
Thanks,
nd65
nd.neal@gmail.com
Re: What 440 rear main seal do you recommend?
[Re: nd65]
#2023111
03/02/16 11:38 AM
03/02/16 11:38 AM
Posts: 13,577 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Lots of threads on this topic here. And lots of opinions on what procedure is best. Have you tried a search?
Master, again and still
[Re: JCCuda]
#2023815
03/03/16 01:13 PM
03/03/16 01:13 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Can you explain how this one piece seal is installed? is it stretched over the crank hub and shrinks back to proper size? Or is it just one long straight piece of rubber seal cut to size?
[Re: rowin4]
#2023855
03/03/16 02:22 PM
03/03/16 02:22 PM
Posts: 447 NJ
JCCuda
NJ
It comes as a 1 piece circle, you make one cut install it then glue the 2 ends together after it's on the crank. Then you slip the seal retainer over top of it. I don't have any pictures before I cut it or with it glued but I've included a picture with it on the crank. I'm not 100% certain that my leak was resolved from the one piece crank seal or from leaving the side seals out and letting the retainer locate itself with the crank seal as opposed to the side seals.
[Re: nd65]
#2023952
03/03/16 05:03 PM
03/03/16 05:03 PM
rowin4
There was another thread about leaking rear seals , maybe more but in one of them I stated that I had been rebuilding big block mopars since the early 70's and never had a leak. Well I never should have said anything as the one I just put together this week is leaking. Crap. I don't think it is the actual crank seal but the plastic retainer side sticks. They should have suck with the old cardboard ones.
[Re: JCCuda]
#2023963
03/03/16 05:15 PM
03/03/16 05:15 PM
Posts: 289 Lowes
steve660
Lowes
It comes as a 1 piece circle, you make one cut install it then glue the 2 ends together after it's on the crank. Then you slip the seal retainer over top of it. I don't have any pictures before I cut it or with it glued but I've included a picture with it on the crank. I'm not 100% certain that my leak was resolved from the one piece crank seal or from leaving the side seals out and letting the retainer locate itself with the crank seal as opposed to the side seals. Cool idea... Got me to thinking, couldn't you use a stock 2 piece seal with both halves turned 90 degrees and get similar results? Put grease on crank to hold both halves in place then carefully set the crank in. Of course you couldn't install it with crank already in the block. Just thinking out loud.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: nd65]
#2023979
03/03/16 05:36 PM
03/03/16 05:36 PM
Posts: 31,340 Oregon
AndyF
Thanks,
nd65
nd.neal@gmail.com You shouldn't have any trouble with a factory crank since it will have the correct knurling on it. Some aftermarket cranks are knurled and some are smooth. With the smooth ones you need to be careful on which seal you use. I think the choices are more limited now on the rear main seals.
[Re: steve660]
#2024263
03/04/16 01:49 AM
03/04/16 01:49 AM
rowin4
It comes as a 1 piece circle, you make one cut install it then glue the 2 ends together after it's on the crank. Then you slip the seal retainer over top of it. I don't have any pictures before I cut it or with it glued but I've included a picture with it on the crank. I'm not 100% certain that my leak was resolved from the one piece crank seal or from leaving the side seals out and letting the retainer locate itself with the crank seal as opposed to the side seals. Cool idea... Got me to thinking, couldn't you use a stock 2 piece seal with both halves turned 90 degrees and get similar results? Put grease on crank to hold both halves in place then carefully set the crank in. Of course you couldn't install it with crank already in the block. Just thinking out loud. I don't see a problem with doing that but I also don't believe that the main seal is the cause of the majority of the leaks. It's the side seals, either to loose or you have to pound them in.
[Re: nd65]
#2024390
03/04/16 10:58 AM
03/04/16 10:58 AM
Posts: 5,199 CT
GTX MATT
CT
The rope seals are a PITA to cut, I used a rope one and rubber side seals and mine is leaking. I really did not like the rubber side seals, I will fill them with RTV next time as much as I don't like that idea either.
Monte Smith had what I thought was a very good suggestion, and I'm going to try this when I try to fix mine. His point was that it is really the side seals or the retainer being off that cause the rear main to leak, because they force the seal to fit too tightly or loose on either side of the crank. He suggested clocking the seal 90 degrees so that the parting line is at the top and bottom (in place on the crank) and then setting the retainer in place, taking care to make sure it was centered around the crank seal and distributing pressure evenly. If necessary you may need to oblong the holes for the bolts. Insert the bolts and lock them down, then fill the sides with RTV.
[Re: GTX MATT]
#2024412
03/04/16 11:43 AM
03/04/16 11:43 AM
DaytonaTurbo
Manitoba, Canada
He suggested clocking the seal 90 degrees so that the parting line is at the top and bottom (in place on the crank) and then setting the retainer in place, taking care to make sure it was centered around the crank seal and distributing pressure evenly. I thought the instructions with the rear mains seals specifically stated to do this. I think I clocked my last one 45* instead of 90, but the idea is the same, to have a solid, continuous groove center the halves of the seal. I think next time I will try rtv instead of the "soak em in solvent and squish them quickly while trying to not [censored] them up and scrape too much cardboard off" side seals.
[Re: nd65]
#2024472
03/04/16 01:34 PM
03/04/16 01:34 PM
Posts: 9,008 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
The side seal strips have to be DRY, no oil, when installed. Put a dab of black sealer on the ends, make sure retainer is square, like a main cap is done and the end strips will expand once oil hits them. The neoprene circle seals don't line up with the knurl any way, would eat it up. Oil dissolves silicone, it will release from the surfaces after awile = oil leak.
