Aluminum main caps or Billet with a girdle? #2023920
03/03/16 05:08 PM
03/03/16 05:08 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Just what it says. For the new 499" low deck. Which do you prefer? Half fill also maybe?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023935
03/03/16 05:33 PM
03/03/16 05:33 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Race only,1/2 fill,studs and aluminum caps.
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023936
03/03/16 05:34 PM
03/03/16 05:34 PM
an8sec70cuda Offline
I'd do aluminum caps and studs. Nothing else.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023937
03/03/16 05:38 PM
03/03/16 05:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I am on record as thinking the girdles are a waste. With a stock block, I have had good success with a fill, aluminum caps, alum rods and good studs. Just don't think the girdle in any way addresses the problem with these blocks. Others disagree and that's fine.
Many will say they have a girdle, X amount of power and no broken blocks. That is likely true. I can also say I have run 1000hp stock blocks with just the caps. Now how long would that block HAVE lasted if run for a long time......I have no idea, just like they have no idea how long it will last with a girdle. Stock block is a crap shoot at best, regardless of how you prepare it at a big HP level.
Re: Aluminum main caps or Billet with a girdle? [Re: Monte_Smith] #2023965
03/03/16 06:18 PM
03/03/16 06:18 PM
I agree with using the after market main caps and studs, no girdle tsk But I don't use block fill either though shruggy
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023968
03/03/16 06:21 PM
03/03/16 06:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
1/2 fill and studs is all I ever do.
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023991
03/03/16 07:06 PM
03/03/16 07:06 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Is the short fill an issue for cooling as street car?
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2023996
03/03/16 07:15 PM
03/03/16 07:15 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
After a ton of reading, I went with Aluminum caps and studs. Everything looked perfect when I did the winter refresher, the mud truck probably spends more time at WOT then most bracket cars but its hard to compare.
Curious on other peoples thoughts though, I was reading some LS stuff today. Would pinning the cap, or a dowel type sleeve on the bolt like a rod help anything? would it even be possible? less room on the cap surface I think. seems popular with the ls guys.
Re: Aluminum main caps or Billet with a girdle? [Re: CTD5.9] #2024002
03/03/16 07:28 PM
03/03/16 07:28 PM
What did the side of the aluminum main caps and the block main cap register look like?How is the mating surfaces between the main caps and block? Is it walking or transferring metal, fretting? work BTW, it ain't a Chevy whistling grin
Re: Aluminum main caps or Billet with a girdle? [Re: Cab_Burge] #2024043
03/03/16 08:33 PM
03/03/16 08:33 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
They argue about girdles, so the world isn't that different over there!
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2024109
03/03/16 10:24 PM
03/03/16 10:24 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I run a girdle and steel caps with a short fill, engine has been together and raced 10 years, been freshened twice, all has looked ok, I went that route since it just didn't seem to be a good idea to have the aluminum caps with the old stock cast iron block. If I was rebuilding Id go the other way though I think. Ive seen enough of the stock block aluminum caps hold up that even though it didn't sound good to me back about 12 years ago when I started building that engine I'd go that route now, I would do a short fill though either way.
Re: Aluminum main caps or Billet with a girdle? [Re: wyoming] #2024111
03/03/16 10:28 PM
03/03/16 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Eric, my new 512 will have aluminum cap's,studs and girdle, all BCR stuff, my machinist advised me against any fill in the block.
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2024186
03/04/16 12:07 AM
03/04/16 12:07 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
our stuff is all USA made with USA materials, we've had a lot of success with the girdles and I tell people its just and insurance thing. some people don't think they need them others like having them. only you and your engine builder can make the call.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Aluminum main caps or Billet with a girdle? [Re: JAMESDART] #2024197
03/04/16 12:35 AM
03/04/16 12:35 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I think it is. I had a 500" low deck in my 9 second 69 Dart, after 15 minutes of street cruising my oil would get hot and would idle at 18-20 pounds at a stop light, always made me nervous. Now I have a 500" low deck in my Duster with no filler and it doesn't cook the oil.
I think a good oil cooler setup would help tremendously though.
Re: Aluminum main caps or Billet with a girdle? [Re: ProSport] #2024244
03/04/16 02:22 AM
03/04/16 02:22 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
On my 505 stroker pump gas engine I used the BCR girdle ,aluminum main caps, ARP studs. Block is 1/2 filled. After 8 years of running close to 1,000 1/4 mile hits the block wasn't cracked, no cap walk . If it last another 8 years I'll be to old to get in the car, well maybe out of it.
Re: Aluminum main caps or Billet with a girdle? [Re: rowin4] #2024667
03/04/16 09:12 PM
03/04/16 09:12 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds like a good setup.
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2024685
03/04/16 09:53 PM
03/04/16 09:53 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Personally, I don't think a short, or even medium fill hurts cooling. These motors circulate little water at the bottom of the cylinders anyway. All the heat is at the top of the bore
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2024789
03/05/16 12:54 AM
03/05/16 12:54 AM
Superfreak
Superfreak
What happened to the piece that BG built you if you don't mind me asking?
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2024791
03/05/16 01:04 AM
03/05/16 01:04 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
I let someone else try to fix it when the block sprung a leak. Downhill from there. Bob built a nice piece.👍
Re: Aluminum main caps or Billet with a girdle? [Re: Eric] #2025281
03/05/16 09:56 PM
03/05/16 09:56 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
For what its worth i have a 484ci(low deck)It ran 8.90's in a 3500lb car the block is half filled(never gets hot)and has the Aluminum main caps....No matter how hard i try...missing gears i can't kill that motor....going on 15 years now
