anyone familiar with these rods
#2023256
03/02/16 04:25 PM
03/02/16 04:25 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
just looking around at rods. these any good? brand? http://www.ebay.com/itm/182039681419?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: anyone familiar with these rods
[Re: mopar dave]
#2023302
03/02/16 05:16 PM
03/02/16 05:16 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Looks like a chinese copy of a good rod.
What brand just broke in there? Might find a set of the same ones and have them checked real good and match them to whats in there, you could save money on balancing again if you get ones that weigh the same. So you buy $300 rods and $200 to rebalance, you just as well buy at least a SCAT H beam for $500 and end up with a better rod than the one linked to.
Of course if the crank has to be replaced none of that matters but I would still get a reputable rod from SCAT callies...
[Re: mopar dave]
#2023321
03/02/16 05:49 PM
03/02/16 05:49 PM
Posts: 4,457 Washington
madscientist
Washington
I can't get the link to work either. All those rods come out of two or three different factories. The brand does not matter they are all the same.
With that said, some of the rods are machined in China and some are machined here. It makes no difference as every part should be measured Before you use it. I bought that rod, or something close to it. The big ends were .0005-.0006 under minimum and the pin ends were .0003-.0005 under. Which was fine because I honed them to fit. Better under than over.
[Re: fbs63]
#2023338
03/02/16 06:28 PM
03/02/16 06:28 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I just built a 440 for a customer with Callies Compstar rods. Super nice quality pieces for the money. If they make what you need, I would use them. JMHO. I agree. Beat on a set of them with my 422, new owner had motor freshened and still using the same set. Been in that block 9 or 10 years now. Best Machine really liked them, that's why I went with them when I did.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2023353
03/02/16 06:49 PM
03/02/16 06:49 PM
Posts: 4,209 New York
polyspheric
New York
I'd like the name of the Washington [censored] who decided to not require imported goods to be identified by country of manufacture. Clinton, perhaps? Not that it makes any difference for now: "no name given" = China, but China is feeling pressure from the other Pacific rim countries with cheaper labor, fewer regulations, and more officials with their hands out. In 5 years "no name given" may = Myanmar.
I've heard K1 makes a good cheap rod.
Boffin Emeritus
[Re: mopar dave]
#2023369
03/02/16 07:11 PM
03/02/16 07:11 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#2023375
03/02/16 07:28 PM
03/02/16 07:28 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm on my 3rd engine rebuild on my 408 engine with K1 H beem rods. Lots of passes but I'm kinda gentle on rods shifting between 6400-6800. I always spend a few extra bucks on the upgraded bolts.
[Re: mopar dave]
#2023454
03/02/16 09:56 PM
03/02/16 09:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dave.. I've been running Eagle H-beams for years.. BUT I bought 3 or 4 sets when they first came out with them... my opinion is they were better quality back then... on one of my engines they went to 9600 rpm a couple of times and 8200 ALL the rest of the time but I did opt for the 2000 bolts in them and had each set checked for size.. and ALL my engines run .003/.003 with half groove mains... I have stayed with what has worked for me EDIT IF I were looking right now.. it would be K-1 H-beams
[Re: MR_P_BODY]
#2023879
03/03/16 04:05 PM
03/03/16 04:05 PM
dogdays
Compstar, Eagle, Scat, Molnar, K1, 440Source, ProComp, StarGalaxy, etcetcetc are ALL forged in China. If you're not paying $800 or more for a set of rods it wasn't forged here. Okay, Howard's has some for chevies that are made here and under $800.
The basic strength and structural integrity of the rods doesn't seem to be in question any more. Machining does. That is where one company may shine.
I think that any of these rods will take as much as a stock block, if the machining is corrected.
R.
