Page 4 of 16 1 2 3 4 5 6 15 16
Re: carnage at the dyno [Re: HotRodDave] #2022952
03/02/16 01:14 AM
03/02/16 01:14 AM
Washington
madscientist Offline
Washington
Originally Posted By HotRodDave
I been studying hard the oiling in my stroker I am building and it seems the full groove would help the rod bearings live longer because they have access to pressurized oil when the cylinder pressure is highest. The 1/2 groove only sends pressurized oil to the rod on the bottom half of the stroke. Weather or not that amounts to a hill of beans under dynamic conditions I could not tell you but it does seem odd they do it that way from the factory.
In order to keep more oil on the crank on mine I drilled smaller oil feed holes in the cam bearings as they are getting fed right off the oil going to the mains. When everything is done right in a SB oiling don't seem to be a big issue from what I have seen. I almost always use standard volume pumps and don't seem to have much issue getting enough pressure.
The issue is the oil timing is wrong on these engines. You should have full oil pressure to the rods at 70* ATDC and that is IIRC but it is close to that. That's why a Chevy doesn't need full groove mains. The Chryslers get full oil pressure way before they need it so the full groove mains helps that. Seems to be worse on the SB but it is wrong on both. The higher the engine speed, the worse it gets.
There are only two fixes for the high rpm stuff (unless you get a block that has the oil passage in the correct location).
One is have a crank drilled with the oil hole turned counterclockwise. The other is more complicated. That is the only way I know to correct it.
Re: carnage at the dyno [Re: ProSport] #2022959
03/02/16 01:31 AM
03/02/16 01:31 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I still haven't given up on the SB yet. I was offered a good 360 block from a member here. Just pay freight. There are a lot of good guys on this forum. I'm interested. I will need a set of rods and 2 pistons a rebalance and a cam. That's doable. I might even have the crank ground for more stroke. Will see. Thanks again guys
Re: carnage at the dyno [Re: mopar dave] #2022963
03/02/16 01:38 AM
03/02/16 01:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave you're making me rethink using 1/2 groove mains on my 434. I had to order a set of .001" unders so I have the other grooved half. My rods are 2.00" and the clearances are .0023-.0025" using King aluminum rod bearings and King mains.
Re: carnage at the dyno [Re: justinp61] #2023002
03/02/16 03:26 AM
03/02/16 03:26 AM
Mt Morris Michigan
Mt Morris Michigan
well, i'm not certain what caused this yet. I will get it apart and examined sunday and go from there. I may change this build up alittle with possible added stroke and more cam.
Re: carnage at the dyno [Re: mopar dave] #2023015
03/02/16 04:26 AM
03/02/16 04:26 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I wouldn't be so quick blame the mains, or crank needs cross drilled, or anything else. My first thought is it was too tight
Re: carnage at the dyno [Re: mopar dave] #2023029
03/02/16 06:07 AM
03/02/16 06:07 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Originally Posted By mopar dave
thanks. first time it happened to me. i think this was the 5th engine i put together and the first to explode. the number 8 piston looks like the pin was trying to come out the bottom. ill post some pics at the end of the week when i get it apart.
Dont forget to look into this.
Would not be surprised if your problems are related to this, rods dont try to pul a pin out of the piston without reason.
Re: carnage at the dyno [Re: mopar dave] #2023030
03/02/16 06:09 AM
03/02/16 06:09 AM
Wild West
M_D Offline
M_D  Offline
Wild West
Obviously it's important to have adequate oil delivery to bearings, and to have proper clearance which will vary depending on the engine and type of usage.
One thing that is often overlooked is the bore of the rod must be round, straight, and sized properly. It's about as important as round and true crank journals and round and straight cylinders. When the bearings are encapsulated in the assembled rod, if the bearing shells are not evenly and tightly contacting the rod bore they can walk around, and they also heat up significantly more because the poor contact between the bearings and rod doesn't transfer heat away from the bearing very well. The bearing shell is then prone to distort from excess heat and lack of support, which usually reduces the oil clearance, which is the beginning of the end.
That may not be what caused your problem, but it's very possible it was. If bearing to journal clearances are on the tight side that's 2 strikes. A lot of rods are honed with methods that are "iffy" and when not done correctly make the bearing bore bell-mouthed. I always inspect and measure the rod bores. On engines that have some run time on them you can look at the contact surfaces on the back of the bearing shells and the bores and see how well they fit.
Re: carnage at the dyno [Re: mopar dave] #2023037
03/02/16 06:43 AM
03/02/16 06:43 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Real sorry to see this Dave, i've put street stuff together but would rather have a motor done by a professional when it's going to see a lot of rpm and has high cost parts.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: carnage at the dyno [Re: deaks] #2023123
03/02/16 01:10 PM
03/02/16 01:10 PM
Mt Morris Michigan
Mt Morris Michigan
Believe me that thought entered my mind when I seen oil gushing from the bottom of the pan. I'll see how I feel about that when its ready for assembly.
Re: carnage at the dyno [Re: M_D] #2023128
03/02/16 01:12 PM
03/02/16 01:12 PM
Mt Morris Michigan
Mt Morris Michigan
I will never use another set of used rods.
Re: carnage at the dyno [Re: Monte_Smith] #2023131
03/02/16 01:15 PM
03/02/16 01:15 PM
Mt Morris Michigan
Mt Morris Michigan
Looking at the broken parts that fell out I think your right. Too tight and not enough oil.
Re: carnage at the dyno [Re: mopar dave] #2023136
03/02/16 01:24 PM
03/02/16 01:24 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
There was killer rotating assy on here a few weeks ago. Killer rods, and Killer stroker crank, don't know your cash flow, but it was reasonable.
Re: carnage at the dyno [Re: mopar dave] #2023137
03/02/16 01:25 PM
03/02/16 01:25 PM
Mt Morris Michigan
Mt Morris Michigan
Here's another thing to think about. The last two builds(408) had .002 on rods and mains and never had a failure but had full groove mains.
Re: carnage at the dyno [Re: mopar dave] #2023144
03/02/16 01:36 PM
03/02/16 01:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You said rods were used and new bolts installed. Were big ends checked for size and roundness
Re: carnage at the dyno [Re: mopar dave] #2023153
03/02/16 01:51 PM
03/02/16 01:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
On big blocks there's a wide groove bearing and a narrow groove bearing. Both are full groove. I use the narrow groove.
Re: carnage at the dyno [Re: Monte_Smith] #2023211
03/02/16 03:31 PM
03/02/16 03:31 PM
Mt Morris Michigan
Mt Morris Michigan
yes they were checked at a machine shop. i checked bearing clearance again before assembly.
Re: carnage at the dyno [Re: FastmOp] #2023214
03/02/16 03:32 PM
03/02/16 03:32 PM
Mt Morris Michigan
Mt Morris Michigan
if i remember right i believe these calico bearings were a narrow bearing. i used a federal mogul main bearing.
Re: carnage at the dyno [Re: mopar dave] #2023215
03/02/16 03:35 PM
03/02/16 03:35 PM
Mt Morris Michigan
Mt Morris Michigan
i'm also second guessing the oil mods as a cause. i have heard the guy that posted those his engine also came apart. not saying thats the cause, but not sure i want to perform those mods on next block.
Re: carnage at the dyno [Re: mopar dave] #2023232
03/02/16 04:04 PM
03/02/16 04:04 PM
Washington
Washington
I doubt that clearance was too tight, but I don't remember what oil you used. I am about ready to fire mine off and it has .0021 on the rods and .0024 on the mains. I'm going to use a 5w30 oil. If yours was too tight I'll be screwed just like you.
I think a lighter grade oil and FGM's and you will be ok.
Re: carnage at the dyno [Re: madscientist] #2023242
03/02/16 04:15 PM
03/02/16 04:15 PM
Mt Morris Michigan
Mt Morris Michigan
joe gibbs xp4 15/50 non synthetic(breakin). like i said last 2 builds had .002 on rods and mains with full groove and using 20/50 amsoil, no issues. i had 100# oil pressure when first fired up, 75 when it got warm and 55 when it let go.
