Re: 60 Dodge D100 driveline parking brake conversion?
[Re: poorboy]
#2023351
03/02/16 06:47 PM
03/02/16 06:47 PM
dogdays
Agreed.
I'd look for a 1965-and-up rear. You can keep your original center chunk. It shouldn't be too hard to mate the original emergency brake cable with the cables from the axles.
As far as the backing plates go, I believe they will swap. But those tapered axles...
R.
[Re: DodgeTruckDude]
#2023425
03/02/16 09:11 PM
03/02/16 09:11 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Different bolt pattern on the backing plates (early on left in pic below), some folks over on the FL forum have redrilled the holes but not worth it IMHO. Change the whole rear end.
[Re: dogdays]
#2023718
03/03/16 11:29 AM
03/03/16 11:29 AM
Posts: 43,629 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Agreed.
R. There are differences in the earlier center section as compared to later, I just went through this on a 61 Dodge D100 and you CANNOT use a later section in an earlier rear! It would be MUCH easier as mentioned above to change out the entire rear end assembly.
JB Rhinehart, Realist
A-Body's RULE!
[Re: dogdays]
#2023888
03/03/16 04:14 PM
03/03/16 04:14 PM
John_Kunkel
Rio Linda, CA
Differences in early/late are the thrust block width in non-SG units and some early units that appear to be 8 3/4" are actually 8 1/4" with an 11-bolt housing. 8 3/4" are all 10-bolt.
#2030917
03/14/16 02:15 PM
03/14/16 02:15 PM
Posts: 10,646 Freeport IL USA
poorboy
Freeport IL USA
The reality is, most guys that are using 727s seldom ever use an e-brake, unless they have to go through an inspection that requires it to function. Even with new parts, if an e-brake is not regularly used, after a couple of years, they don't work because the cable have frozen up. You can usually create enough force with a foot pedal to activate them, but the return springs on the cable inside the drum won't have enough pressure to push the cable back and they probably won't release.
I've had my automatic equipped Dakota for 4 years, in 4 years of use, I don't ever remember using the e-brake. I would be afraid that if I used it now, the e-brake would never release again.
Unless you really feel a need, or are required to have a functioning e-brake, and you are installing an automatic, an e-brake wouldn't be a very high priority to me, at least in my world. Gene
