01 Neon accessory problem #2022710
03/01/16 06:26 PM
03/01/16 06:26 PM
Marion, Ohio USA
kab69440 Offline OP
kab69440  Offline OP
Marion, Ohio USA
I have an 01 Neon 2.0/ 5-speed sitting out back and I am attempting to figure out why several accessories do not work while the engine is running. Turn signals, radio, blower motor, wipers, power outlet- all of these things work fine in the ignition on keyswitch position. They do not work in the ACC or engine run keyswitch position.
I am going to go out on a limb and guess that either there is a wire off/ broken at the switch or the switch itself is faulty. Nothing else makes sense. Well, I'm going to grab my scanner and multi-meter, head out back and start tearing things apart. I would appreciate hearing of similar problems being resolved and other ideas as well. Thanks all, and wish me luck!
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: 01 Neon accessory problem [Re: kab69440] #2022879
03/01/16 11:39 PM
03/01/16 11:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like switch issue. Normally you can feel an indexing problem in the key cylinder though.
Re: 01 Neon accessory problem [Re: kab69440] #2023325
03/02/16 05:55 PM
03/02/16 05:55 PM
Marion, Ohio USA
kab69440 Offline OP
kab69440  Offline OP
Marion, Ohio USA
Replaced ignition switch. Problem solved.
