Question about surface rust #202265
01/23/09 08:31 PM
01/23/09 08:31 PM
CA
David Lee Offline OP
CA
On my trunk lid and many other parts of my cuda body I have patches of rust. Should I sand just those areas down now and cover them with a bit of rustoleum or sand the whole thing down now and cover it with some anti rust oil?
Re: Question about service rust [Re: David Lee] #202266
01/23/09 11:12 PM
01/23/09 11:12 PM
Mass
Mike Mancini Offline
Mass
Personally, I wouldn't touch it. Leave it as is. I'd rather see a little surface rust than spray bomb primer.
Mike Mancini
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: Question about service rust [Re: Mike Mancini] #202267
01/24/09 12:36 AM
01/24/09 12:36 AM
CA
CA
I was not going to spray bomb it, I was going to cover it with a coating of this stuff.
CRC 3-36 prevents rust and
corrosion by displacing and
sealing out moisture and by
forming a continuous protection
barrier against water and oxygen
Re: Question about service rust [Re: David Lee] #202268
01/24/09 12:44 AM
01/24/09 12:44 AM
Jacksonville Florida
elitecustombody Offline
that is alot better than letting it sit and rust away
Re: Question about surface rust [Re: David Lee] #202269
01/24/09 12:56 AM
01/24/09 12:56 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I would sand them completely out now before the rust etches deeper. Properly prep, prime and even spry bomb a color close to what you have. Primered metal doeds not weather well without a top coat.
Re: Question about surface rust [Re: NITROUSN] #202270
01/24/09 06:12 PM
01/24/09 06:12 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I agree, sand,seal/primer, spray a color on it..or use a very good primer/sealer product...primer alone is not a good sealer...and is that a tarp on it?...that's not a good thing for it either...holds in moisture...
