Re: Ramcharger air box
[Re: 70 buzz]
#2022566
03/01/16 01:45 PM
03/01/16 01:45 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
69 was a combination of rivets and bolts, looks like Chrysler smartened up and changed that for 1970 , or sometime during the 70 model year ?
[Re: 70 buzz]
#2022644
03/01/16 04:06 PM
03/01/16 04:06 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I've seen several '70's that I believe to be original without any rivits, just the bolts and J nuts.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 70 buzz]
#2023179
03/02/16 02:48 PM
03/02/16 02:48 PM
JohnRR
U.S.S.A.
Here is another shot of a 70 hood that took the bolts with the u-nut. Convinced the 69 ramcharger was attached with rivets and the 70 ramcharger with bolt and u-nuts I have had multiple 69 ramcharger/air grabber hoods over the years, all of the ductwork is riveted to the hood, the only bolts are on the outer ends near the fenders.
[Re: JohnRR]
#2023231
03/02/16 03:57 PM
03/02/16 03:57 PM
Posts: 1,893 michigan
70 buzz
michigan
Here is another shot of a 70 hood that took the bolts with the u-nut. Convinced the 69 ramcharger was attached with rivets and the 70 ramcharger with bolt and u-nuts I have had multiple 69 ramcharger/air grabber hoods over the years, all of the ductwork is riveted to the hood, the only bolts are on the outer ends near the fenders. 69 yes change for 70 hood bolt
