Engine starting problem #2022453
03/01/16 10:56 AM
03/01/16 10:56 AM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
I have a 340 in a 72 dart with electronic ignition. Recently i started having an issue with it starting. It cranks fine but won't start until i am letting off the key then fires. I put a new box and ballast resistor on it, still have the problem. Any ideas? Thanks
Re: Engine starting problem [Re: dartphil] #2022467
03/01/16 11:20 AM
03/01/16 11:20 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this is the 'classic' bad ballast symptom. i know you said you replaced the ballast but...
try jumping the ballast by connecting the wires together and see if it starts. you won't damage anything running it for a short period of time.
Re: Engine starting problem [Re: mikemee1331] #2022501
03/01/16 12:00 PM
03/01/16 12:00 PM
OE 5 pin ECU/4 terminal "dual" ballast or 4 pin ECU/2 terminal "single" ballast setup? pull the yellow with tracer wire from the starter relay to disable the starter and turn the key on and (1) the coil positive primary terminal and (2) the blue/yellow ECU terminal must be hot in ign1 "run" for the ign to function. If not, check the bulkhead & work forward or backward to find the open. grab your meter. EDIT only need to pull the yellow w tracer wire off of the "ign" terminal on the starter relay if you are checking things out in the ign key to "start" position. I'm just so used to checking both back to back
Re: Engine starting problem [Re: RapidRobert] #2022632
03/01/16 03:48 PM
03/01/16 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If changing the ballast didn't help, it's likely the bulkhead disconnect.
Re: Engine starting problem [Re: John_Kunkel] #2022938
03/02/16 12:59 AM
03/02/16 12:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Maybe I am reading this wrong but does he not say it wont fire until he lets off the key ? To me that means no spark while cranking but it does fire with the key in the on posistion which would not be a ballast problem. Ron
Re: Engine starting problem [Re: John_Kunkel] #2022944
03/02/16 01:07 AM
03/02/16 01:07 AM
Kirkland, Washington
Pacnorthcuda Offline
Correct. Bulkhead connector. To the OP, disco the connector and clean the terminals. You will fix it.
Re: Engine starting problem [Re: Pacnorthcuda] #2025605
03/06/16 11:49 AM
03/06/16 11:49 AM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Thanks guys, I'm still messing with it. I have a remote starter button hooked up under the hood and it starts fine. I been messing with the bulk heads and still when i turn the key to start with my test light hooked up the test light goes out.
Re: Engine starting problem [Re: dartphil] #2025888
03/06/16 07:34 PM
03/06/16 07:34 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
FIXED !!!! It was the plug under the dash from the starter switch.
Re: Engine starting problem [Re: Pacnorthcuda] #2025922
03/06/16 08:16 PM
03/06/16 08:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
awesome and thanks for getting back to us!
Re: Engine starting problem [Re: mikemee1331] #2026035
03/06/16 10:15 PM
03/06/16 10:15 PM
Which plug (out of curiousity)
