Re: Fuel pressure regulator location question
[Re: superchuck]
#2022457
03/01/16 11:08 AM
03/01/16 11:08 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Yes...not supposed to mount them on the firewall.
[Re: superchuck]
#2022458
03/01/16 11:08 AM
03/01/16 11:08 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Rulebook clearly states that is the ONLY place you can't mount it.
IHRA rulebook Page 81
http://www.mydigitalpublication.com/publication/?m=1203&l=1#{"issue_id":285638,"page":0}
Joe
Without Data, you’re just another guy with an opinion.
[Re: superchuck]
#2022468
03/01/16 11:21 AM
03/01/16 11:21 AM
Posts: 200 midwest
superchuck
On thin ice
On thin ice
midwest
I just read page 81 and it basically says you can mount it there. Read the last 2 sentences.
[Re: superchuck]
#2022472
03/01/16 11:24 AM
03/01/16 11:24 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Old rule book, but:
1:5 FUEL SYSTEMS Location: All fuel tanks, lines, pumps, valves, etc. must be outside of the driver’s compartment and within the confines of the frame and/or steel body. Cool cans, fuel-distribution blocks, etc. must be located at least 6 inches forward of the flywheel/bellhousing area on rear-wheel-drive (RWD) vehicles, and on opposite side of flywheel/housing area on front-wheel-drive (FWD) vehicles. Fuel pressure gauge isolators, with steel braided line, may be mounted on firewall.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: superchuck]
#2022478
03/01/16 11:28 AM
03/01/16 11:28 AM
an8sec70cuda
On old Mopars, the firewall is definitely not 6" forward of the flywheel/bellhousing area. Why would it be legal to mount a regulator, but not a fuel distribution block, on the firewall?
[Re: superchuck]
#2022572
03/01/16 01:55 PM
03/01/16 01:55 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have seen them mounted IFO the front carb or on the fenderwell. Front of the carb supposedly is the ideal location.
[Re: OUTLAWD]
#2022599
03/01/16 02:39 PM
03/01/16 02:39 PM
Posts: 11,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Old rule book, but:
1:5 FUEL SYSTEMS Location: All fuel tanks, lines, pumps, valves, etc. must be outside of the driver’s compartment and within the confines of the frame and/or steel body. Cool cans, fuel-distribution blocks, etc. must be located at least 6 inches forward of the flywheel/bellhousing area on rear-wheel-drive (RWD) vehicles, and on opposite side of flywheel/housing area on front-wheel-drive (FWD) vehicles. Fuel pressure gauge isolators, with steel braided line, may be mounted on firewall. Exactly what it says in the 2016 book. It's always been nothing with fuel in it on the firewall and fuel lines outside of the frame rail or otherwise protected. That's what I read "etc." meaning. The IHRA book says "It must be mounted as far away as possible from the flexplate/flywheel area" if it's on the firewall. To me, that means out in the fenderwell or somewhere away from the engine. How far from the carb do we want the regulator to be? People smarter than me have consistently told me that you want the regulator even with or in front of the carb so the low pressure side of the system is not having to move fuel against the G-forces. Sometimes we overlook the obvious simple things.
[Re: CMcAllister]
#2022606
03/01/16 03:12 PM
03/01/16 03:12 PM
Posts: 289 Lowes
steve660
Lowes
I've been told ideally you want it ahead of the carb.
That way when car launchs all the fuel in the lines running back to carb will be pushed back towards carb, helping eliminate a momentary lean condition..
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: superchuck]
#2022847
03/01/16 10:49 PM
03/01/16 10:49 PM
Posts: 7,506 Az
Crizila
Az
The regulator is for the fuel solenoid for my nitrous. I have no inner fender wells and the area for the fuel inlet on my Holley is already crammed with solenoids, switchs, and the carbs fuel pressure regulator. Maybe I'll mount it to the frame rail ahead of the motor mount and snake the line between the alternator and block. Mine with no inner fender wells. Also run a protective steel plate where my line passes by the trans convertor / flex plate.
Fastest 300
