Page 2 of 16 1 2 3 4 15 16
Re: carnage at the dyno [Re: mopar dave] #2022249
03/01/16 12:04 AM
03/01/16 12:04 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Black crank throw...........it grabbed a bearing.
Main web looks cracked. Possible that happened first. Crank may be broken.
Rod didn't break.......it got sawed off
Re: carnage at the dyno [Re: madscientist] #2022273
03/01/16 12:36 AM
03/01/16 12:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By madscientist
I can't tell from the picks where it got the block. Did it take out a pan rail or something else I missed?
In the first photo, there is a notch in the bottom of the cylinder on the cam side.
Re: carnage at the dyno [Re: Hot 340] #2022280
03/01/16 12:47 AM
03/01/16 12:47 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
why is that. i thought that was the first one to get oil?
Re: carnage at the dyno [Re: justinp61] #2022286
03/01/16 12:50 AM
03/01/16 12:50 AM
Mt Morris Michigan
Mt Morris Michigan
thats from the rod. put a nice notch in it.
Re: carnage at the dyno [Re: mopar dave] #2022293
03/01/16 12:56 AM
03/01/16 12:56 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Im not sure why. Just what ive seen. Ive seen more number 8's jacked up than any of the rest of the journals.
Re: carnage at the dyno [Re: Monte_Smith] #2022317
03/01/16 01:13 AM
03/01/16 01:13 AM
Mt Morris Michigan
Mt Morris Michigan
havent looked at the other bearings yet and wont have time til this weekend, but why would #8 get the least oil.
Re: carnage at the dyno [Re: Hot 340] #2022323
03/01/16 01:15 AM
03/01/16 01:15 AM
Mt Morris Michigan
Mt Morris Michigan
dont make sense. i opened up all those passages. one thing i did do diffently this time was use single groove main bearing. will be going back to a full groove next time for sure.
Re: carnage at the dyno [Re: mopar dave] #2022331
03/01/16 01:22 AM
03/01/16 01:22 AM
Washington
madscientist Offline
Washington
I don't think I ever hurt number 8. If all,it did was notch the bores just sleeve it unless you have a bunch of blocks around.
Re: carnage at the dyno [Re: madscientist] #2022333
03/01/16 01:24 AM
03/01/16 01:24 AM
Mt Morris Michigan
Mt Morris Michigan
didnt take out the pan rail, but it sure did a number on the bottom of the cylinder. pretty sure the block is toast.
Re: carnage at the dyno [Re: mopar dave] #2022365
03/01/16 02:22 AM
03/01/16 02:22 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I feel for your loss, get it apart, sweep up the mess and get after it again. Only thing that gets you over something like that is a newer better one, just like women.
Mopar to the bone!!!
Re: carnage at the dyno [Re: mopar dave] #2022371
03/01/16 02:38 AM
03/01/16 02:38 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That sucks man, sorry to see this.
How much rod bearing clearance did it have?
Re: carnage at the dyno [Re: mopar dave] #2022423
03/01/16 06:45 AM
03/01/16 06:45 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Sorry to hear. Hope things work out for you.
Re: carnage at the dyno [Re: mopar dave] #2022437
03/01/16 10:03 AM
03/01/16 10:03 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
sorry to here that dave ,is it a 4340 crank and were they new rods or new rod bolts
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: carnage at the dyno [Re: mopar dave] #2022452
03/01/16 10:54 AM
03/01/16 10:54 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
what was the oil system; pan, pick-up, pump?
Re: carnage at the dyno [Re: mopar dave] #2022456
03/01/16 11:07 AM
03/01/16 11:07 AM
an8sec70cuda Offline
Wow, sorry to see this! Hopefully you can salvage the topend and get something going again soon.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: carnage at the dyno [Re: mopar dave] #2022471
03/01/16 11:23 AM
03/01/16 11:23 AM
gregsdart Offline
gregsdart  Offline
Hopefully the block can be saved? Never done it, but maybe a Diesel engine repair shop might be able to weld up any cracks.
Re: carnage at the dyno [Re: mopar dave] #2022486
03/01/16 11:44 AM
03/01/16 11:44 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Sucks. Been there (not on dyno) but had one come apart at 7,200. Not much left and just had to start completely over.
Re: carnage at the dyno [Re: mopar dave] #2022511
03/01/16 12:31 PM
03/01/16 12:31 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Sorry to hear this. frown
72 Plymouth Roadrunner 11.08@123.25
Re: carnage at the dyno [Re: dizuster] #2022540
03/01/16 01:10 PM
03/01/16 01:10 PM
Mt Morris Michigan
Mt Morris Michigan
a little over .002" (.00225)? and .0033" on mains. only thing I did different was I used a single groove main bearing. the block,crank and rods came from the last build I had and it went 8yrs. that last build had .002 on the mains and rods and never had a issue.
Re: carnage at the dyno [Re: Roughbird72] #2022544
03/01/16 01:17 PM
03/01/16 01:17 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Sorry to hear it man, I feel your pain I lost one on the dyno about a year ago it didnt break anything but burnt the crank and one rod. It happened on the forth dyno pull and was also down about 50 h.p.. I would have been real upset if it hurt my R3 block as they are almost impossible to find. This is also why I dyno all my motors better on the dyno at the engine builders shop than at the track. It got back together and made even more power and torque than what I expected for what the combo is. I hope you find the problem
And build it even stronger and better.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
