Re: carnage at the dyno
[Re: mopar dave]
#2022249
03/01/16 12:04 AM
03/01/16 12:04 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Black crank throw...........it grabbed a bearing.
Main web looks cracked. Possible that happened first. Crank may be broken.
Rod didn't break.......it got sawed off
[Re: madscientist]
#2022273
03/01/16 12:36 AM
03/01/16 12:36 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
I can't tell from the picks where it got the block. Did it take out a pan rail or something else I missed?
In the first photo, there is a notch in the bottom of the cylinder on the cam side.
[Re: mopar dave]
#2022293
03/01/16 12:56 AM
03/01/16 12:56 AM
Posts: 3,397 Pa
Hot 340
Pa
why is that. i thought that was the first one to get oil? Im not sure why. Just what ive seen. Ive seen more number 8's jacked up than any of the rest of the journals.
[Re: mopar dave]
#2022331
03/01/16 01:22 AM
03/01/16 01:22 AM
Posts: 4,457 Washington
madscientist
Washington
dont make sense. i opened up all those passages. one thing i did do diffently this time was use single groove main bearing. will be going back to a full groove next time for sure. I don't think I ever hurt number 8. If all,it did was notch the bores just sleeve it unless you have a bunch of blocks around.
[Re: mopar dave]
#2022365
03/01/16 02:22 AM
03/01/16 02:22 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I feel for your loss, get it apart, sweep up the mess and get after it again. Only thing that gets you over something like that is a newer better one, just like women.
Mopar to the bone!!!
[Re: mopar dave]
#2022456
03/01/16 11:07 AM
03/01/16 11:07 AM
Posts: 13,414 Marion, South Carolina [><]
an8sec70cuda
Wow, sorry to see this! Hopefully you can salvage the topend and get something going again soon.
[Re: mopar dave]
#2022471
03/01/16 11:23 AM
03/01/16 11:23 AM
Posts: 10,030 Frostbitefalls MN (Rocky&Bullw...
gregsdart
didnt take out the pan rail, but it sure did a number on the bottom of the cylinder. pretty sure the block is toast. Hopefully the block can be saved? Never done it, but maybe a Diesel engine repair shop might be able to weld up any cracks.
[Re: Roughbird72]
#2022544
03/01/16 01:17 PM
03/01/16 01:17 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
Sorry to hear it man, I feel your pain I lost one on the dyno about a year ago it didnt break anything but burnt the crank and one rod. It happened on the forth dyno pull and was also down about 50 h.p.. I would have been real upset if it hurt my R3 block as they are almost impossible to find. This is also why I dyno all my motors better on the dyno at the engine builders shop than at the track. It got back together and made even more power and torque than what I expected for what the combo is. I hope you find the problem And build it even stronger and better.
