Source for intake manifold foam end seals? #2021611
02/29/16 12:25 AM
02/29/16 12:25 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
BB/Hemi, those foam end seals for the intake manifold when the valley plate is part of the intake. I need a set and can't find them anywhere.
Can you steer me towards some?
Master, again and still
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2021613
02/29/16 12:34 AM
02/29/16 12:34 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How big is the gap? On small blocks I throw them away and use copper silicone.
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2021637
02/29/16 01:21 AM
02/29/16 01:21 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Member 'roadhazard' makes and sells gaskets. He can probably help you out.
Re: Source for intake manifold foam end seals? [Re: slantzilla] #2021727
02/29/16 04:35 AM
02/29/16 04:35 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I don't think that Superformance makes the valley end gaskets for a Hemi.
I bought their Hemi Intake gaskets (from roadhazard) and they don't come with them.
I can't find them in their catalog.
http://www.superformanceproducts.com/catalog/2016SuperformanceCatalog_RacerNet.pdf
I know that Dan Smith said he usually just uses RTV gasket maker for the valley plates.
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2021774
02/29/16 10:48 AM
02/29/16 10:48 AM
STL
cdstl Offline
cdstl  Offline
STL
I went to a craft store, Michael's, and bought a couple of different thicknesses of foam in sheet form.
PS I saw one of your buddies up here chasing coyotes the other day. We were in a 69 Charger and he started describing your Dart.
Small world
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2021793
02/29/16 12:06 PM
02/29/16 12:06 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I am using the Superformance gaskets which don't come with the end seals which is why I am looking for them. And I have used silicone before and it worked okay, I would just prefer to use the foam for this build.
The craft store foam is an interesting idea. As long as it doesn't become oil soaked or fall apart, it would be worth trying.
Coyotes and Darts. Yeah, we get around.
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2021866
02/29/16 02:25 PM
02/29/16 02:25 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Tough Ultra Black for end seals can't beat it
MLR426
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2022023
02/29/16 07:16 PM
02/29/16 07:16 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Home Depot has any size you want. That's where Ray Barton told me to go. The last time I gave in and used silicon like everyone else and had good results.
2011 Drag Pak Challenger
Re: Source for intake manifold foam end seals? [Re: MLR426] #2022261
03/01/16 12:23 AM
03/01/16 12:23 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
MLR426
iagree
Clean the surfaces with brake clean, acetone, alcohol,
Lay a bead, make sure to have enough in the corners, set the intake, let it cure 24 to 48 hours, trim the excess with a razor blade. twocents
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2022518
03/01/16 12:46 PM
03/01/16 12:46 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I don't think that I will use foam from a craft store or lumber yard. Just too much uncertainty about it's long term ability to resist oil. And I won't use The Right Stuff for the intake ends again. I thought I would need a stick of dynamite to pull the intake last time. That stuff is tough!
So, that leaves the Ultra Black.
Thanks for the help, guys.
Re: Source for intake manifold foam end seals? [Re: TJP] #2022522
03/01/16 12:48 PM
03/01/16 12:48 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
MLR426
iagree
I'll have to agree with the above recommendation of using some Permatex Ultra Black RTV on the block rails. Be certain the surfaces are squeaky clean as suggested.
We don't include the end seals for a few reasons. One being many of these heads and blocks have been milled therefore the gap between the manifold and the block can vary widely.
It is highly doubtful you will find a suitable foam at your local craft store that will stand up to the oil, fuel, heat and compression set.
Ultra Black is where it's at
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2022752
03/01/16 08:15 PM
03/01/16 08:15 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Intake gasket material is available @ Autozone...
http://www.autozone.com/sealants-glues-a.../?checkfit=true
Just my $0.02... wink
Re: Source for intake manifold foam end seals? [Re: cdstl] #2022987
03/02/16 02:29 AM
03/02/16 02:29 AM
STL
cdstl Offline
cdstl  Offline
STL
Small world
Foam no good here, other places it's ok. I am/was an idiot. Use the black stuff Martin recommended.
Re: Source for intake manifold foam end seals? [Re: cdstl] #2024437
03/04/16 01:33 PM
03/04/16 01:33 PM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
I believe I have a drawer full of them from over the years contact me, pm, & once I confirm I can ship some out. Dave SS/ea #1355
Re: Source for intake manifold foam end seals? [Re: DaveRS23] #2024445
03/04/16 01:48 PM
03/04/16 01:48 PM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
Just looked in my box I have all 3 types, cork, foam w/holes, & foam w/o holes, contact me & they're yours. Dave SS/ea #1355
Re: Source for intake manifold foam end seals? [Re: RO23dave] #2024720
03/04/16 10:52 PM
03/04/16 10:52 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Super offer, thank you.
But I think I will join the crowd and use the black RTV.
