DBL springs on production heads #2021500
02/28/16 09:06 PM
02/28/16 09:06 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
I was fitting some stuff up today, and my 308 heads have a raised spring locator boss that the inner spring rests on. My question is, does this need to go?
I already need to narrow the guide so a seal can fit, so it can be done at the same time.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: DBL springs on production heads [Re: poboyengineering] #2021530
02/28/16 10:10 PM
02/28/16 10:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
needs to be cut to fit which ever spring's you are going to use because you need to know what the inner diameter of your springs are and also cup locators if used.
Re: DBL springs on production heads [Re: poboyengineering] #2021541
02/28/16 10:37 PM
02/28/16 10:37 PM
pennsylvania
pennsylvania
I wasn't planning on cup locators, the OD fits the stock relief well. this boss is obviously an internal locator.
If I understand you, dartman, I should cut this to serve as a locator for the inner spring and let the outer be located by the stock relief?
Re: DBL springs on production heads [Re: poboyengineering] #2021856
02/29/16 02:03 PM
02/29/16 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your not using a cup locator then cut that
off and let the OD of the spring to locate it
and dont worry about the inner.. the inner will
follow the outer(assuming the OD of the pocket
is like you say about the fit to the spring)
EDIT
The seal cutting tool I have will cut the guide
OD and that bottom part all in one cut.. make
sure your guide is cut down far enough to clear
the retainer at full lift
wave
Re: DBL springs on production heads [Re: poboyengineering] #2022116
02/29/16 09:35 PM
02/29/16 09:35 PM
pennsylvania
pennsylvania
That's the way it was explained to me, Mr. P. They will go to the shop next week and get cut. Nothing is bolt on, right? Lol.
