Re: vynal top repair
[Re: bonefish]
#2021435
02/28/16 06:17 PM
02/28/16 06:17 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
This is the original top? I suspect you'll destroy the top just trying to get it up enoughto do the repair. And much like those home improvement shows you're likely to discover more issues once you delve in. I'd plan to just remove it and reinstall a new one. They really aren't that difficult to install.
Could it be done? I suspect but the end results may not be any better than the situation you have now in appearance.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: bonefish]
#2021564
02/28/16 11:18 PM
02/28/16 11:18 PM
R70RUNNER
Riverside, Ca
Yep nothing ventured nothing gained. Take some pics as you progress to share if the repair works. Tom
[Re: R70RUNNER]
#2021568
02/28/16 11:23 PM
02/28/16 11:23 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Heat gun will help. If at all possible roll it, don't pull it. Pulling will stretch the material. When you glue it back don't use that cheap 3M stuff in the can. Find a good commercial glue that installers use. Also, bear in mind that there are some primers that glue will not adhere to. Make sure you scuff around the repair and clean with grease and wax remover.
Abe Lincoln
[Re: bonefish]
#2021720
02/29/16 04:11 AM
02/29/16 04:11 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
I've done it. I had a '74 Swinger that was bubbling under the top at the quarter/roof seam on the c-pillar. It was an original car with the original top. As stated above, I carefully heated the top just enough to warm the metal and soften the glue a bit but not melt the vinyl. I was able to carefully peel it up above the seam far enough to grind and wire brush the rusted area and repair it.
I used por-15 on the metal, then filled the seam with fiberglass filler, and sanded and finished the area.I then heated the top and the vinyl again, sprayed the glue and stretched it back down. Still looked nice when I sold the car quite some time later. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
