Extra long crank bolt? #2021208
02/28/16 12:40 PM
02/28/16 12:40 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
While assembling the front end of my engine last night, the crank bolt got soft going in. Come to find out I stripped the last few threads off the bolt. Of course that sinking feeling sets in w/ visions of pulling the engine and complete disassembly and then finding a repair shop for the crank.
After inspection the crank is fine; it was just the bolt. I found a new bolt in my stash of parts and reluctantly used it.
The factory bolt doesn't go in very far w/ a fluid damper and I couldn't find anything online that was longer than 2.25. Do I just need to go to Fastenall and buy a bolt or does someone make one for a Mopar crank?
At this point I'm just really glad the bolt was gr5 and the crank is made of 4340.
Yeah, it's got a smallblock.
Re: Extra long crank bolt? [Re: 340B5] #2021209
02/28/16 12:50 PM
02/28/16 12:50 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
440Source has several listed. They show the factory bolt at 1.25". I can't see why you would need anything longer than 2.25". Make sure you don't bottom it out in the crank threads.
[image][/image]
Re: Extra long crank bolt? [Re: sgcuda] #2021230
02/28/16 01:34 PM
02/28/16 01:34 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I checked that. I'm a long way from bottoming.
Re: Extra long crank bolt? [Re: 340B5] #2021263
02/28/16 02:20 PM
02/28/16 02:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought my grade 8 from Tractor Supply.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Extra long crank bolt? [Re: pittsburghracer] #2021299
02/28/16 03:03 PM
02/28/16 03:03 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
My inner gearhead wants to buy a slightly longer bolt, then gun-drill it. Seems like useless weight being it doesn't hold much.
Re: Extra long crank bolt? [Re: 340B5] #2021315
02/28/16 03:22 PM
02/28/16 03:22 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
I recall that for the Fluidamper you use a small block bolt. Much longer than a stock BB bolt. I switched to ARP bolts and I think their BB bolts are a bit longer than stock but can't say for sure.
Re: Extra long crank bolt? [Re: 340B5] #2021327
02/28/16 03:32 PM
02/28/16 03:32 PM
I bought several 2 1/4 and 2 1/2 grade eight bolts from our local comercial hardware store. I'm using a ATI dampener with a extend hub to use with a milidon gar drive, the stock BB bolt woulndn't engage one thread shock I had one stock SB bolt and I used it to seat the dampeener and it was way long on the thrread engagement so I bought the others one for future use, I ended up using one of the 2 1/4 long ones up
Re: Extra long crank bolt? [Re: 340B5] #2021347
02/28/16 03:49 PM
02/28/16 03:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just buy a grade 8 bolt from a good hardware store.
Re: Extra long crank bolt? [Re: 340B5] #2021394
02/28/16 04:53 PM
02/28/16 04:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just bought a grade 8 bolt from Fastenal.
Re: Extra long crank bolt? [Re: Al_Alguire] #2021443
02/28/16 06:51 PM
02/28/16 06:51 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got mine at Ace hardware,grade 8.
Re: Extra long crank bolt? [Re: pittsburghracer] #2021708
02/29/16 03:40 AM
02/29/16 03:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here... all I buy is grade 8 from there
wave
Re: Extra long crank bolt? [Re: 340B5] #2021780
02/29/16 11:08 AM
02/29/16 11:08 AM
Morrow, OH
Morrow, OH
So for those of you that just buy a bolt what do you do for a washer? That washer is as critical to proper fastening as the bolt itself. That's why I like the ARP so much. Good hardened washer that does not distort.
Re: Extra long crank bolt? [Re: 340B5] #2021790
02/29/16 11:55 AM
02/29/16 11:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also got an xtra long one with a nut and extra washers.I use that as an installation tool.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Extra long crank bolt? [Re: 340B5] #2021810
02/29/16 12:29 PM
02/29/16 12:29 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Like others, I also use grade 8 bolts and washer. I use a tap bolt(fully threaded) and thread a nut on very tight and align the hexes to act as a long bolt head. This way the deep socket and long ratchet DON'T fall off when barring engine over to run valves. I put a center point in the bolt head for puller. twocents thumbs
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Extra long crank bolt? [Re: 340B5] #2021855
02/29/16 02:02 PM
02/29/16 02:02 PM
AndyF Online content
AndyF  Online Content
I use one of the ARP crank bolts. They have 12 point bolts as well as hex bolts that are broached for a 1/2 inch drive. Here is the 12 point bolt.
