Compression Test #2020685
02/27/16 12:40 PM
02/27/16 12:40 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
should I do it with the motor cold or warm? Or does it matter as long as they are all about the same? Thanks
Re: Compression Test [Re: Plymouth340] #2020734
02/27/16 02:14 PM
02/27/16 02:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Warm is best, all plugs removed, battery charger hooked up.
I usually look at what the gauge reads on one pump, 4 pumps, & 8 pumps.
