Torque spec for cam bolts #2020303
02/26/16 04:38 PM
02/26/16 04:38 PM
Dayton, WA
wesgtx440 Offline OP
Dayton, WA
What is the torque spec on a big block 3 bolt roller cam? I have one of those roller bearing/plate assemblies from Mancini. The bolts are torx head. I was guessing somewhere around 20-25 foot pounds?
68 Charger R/T 440 auto
Re: Torque spec for cam bolts [Re: wesgtx440] #2020307
02/26/16 04:45 PM
02/26/16 04:45 PM
The Mopar service manuals show 35 ft lbs. on the stock bolts. I use between 30 and 35 lbs with blue Locktite on my motors up
Re: Torque spec for cam bolts [Re: Cab_Burge] #2020326
02/26/16 05:13 PM
02/26/16 05:13 PM
Dayton, WA
Dayton, WA
Thank you! wrench
