Re: P5 Head
[Re: Coldart]
#2020140
02/26/16 12:21 PM
02/26/16 12:21 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
To far off to change, and the cam tunnel has no possibility of working.
Re: P5 Head
[Re: fishy340]
#2020704
02/27/16 12:10 PM
02/27/16 12:10 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
R3 blocks are as rare as cast p5 heads...Good luck man. Only the 9.580" deck, internal oil pump, bushed for .875 drop in lifter and 4 bolt Billet cap ones everybody thinks they want.lol
Re: P5 Head
[Re: RV2]
#2021464
02/28/16 07:06 PM
02/28/16 07:06 PM
Posts: 6,187 Melbourne , Australia
LA360
Why are there two P5 heads(wedge and Hemi)? Plug location, the Wedge units didn't have the plug lead through the rocker cover. I am fairly certain that Con Sideris here in Australia probably has some left. I know the foundry that cast them still had them left, perhaps try and contact them. http://www.racerpro.com.au/Cheers
Alan Jones
Re: P5 Head
[Re: LA360]
#2021770
02/29/16 09:36 AM
02/29/16 09:36 AM
Posts: 84 Minnesota
Coldart
Minnesota
No castings left, the patterns are still there getting dusty. Alan, what castings were they making? Had heard that someone in Australia was making heads. The mopar castings I'm getting am sure are going to need hrs of tig welding to be useable
Re: P5 Head
[Re: Coldart]
#2022992
03/02/16 01:38 AM
03/02/16 01:38 AM
LA360
Before everyone went to billet heads over here for Pro Stock, a local engine builder (who was taking care of a RWR engine in the Mopar backed entry) was getting them cast. From what I understand they were based on the factory casting, some have said an exact copy. Rumour has it he got into some trouble with Mopar in regards to it. From what I was told they would still crack around the intake port bowl, but I never saw a set that had failed in this manner. The afore mentioned engine builder has since closed his shop, and the foundry that did the castings for him haven't heard from him in some time. The patterns are sitting in storage getting dusty. I worked at a CNC shop that machined the castings for him, I wish I had grabbed the CAD files before I left, but I figured I'd probably never use them.
Alan Jones
Re: P5 Head
[Re: LA360]
#2044757
04/02/16 08:43 PM
04/02/16 08:43 PM
LA360
I am surprised that no one has done a Hemi style head for boosted applications for LA blocks. I am aware of the Hot Rod style head that was done, I'm talking about a balls to the wall style of cylinder head, but then, what block are you going to put it on?
Alan Jones
Re: P5 Head
[Re: Coldart]
#2046555
04/04/16 07:06 PM
04/04/16 07:06 PM
Posts: 3,579 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Can't run billet heads/block Coldart, What sort of car / class are you building the engine for? Thanks, Bill
Re: P5 Head
[Re: Coldart]
#2046753
04/04/16 11:09 PM
04/04/16 11:09 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: P5 Head
[Re: Coldart]
#2046759
04/04/16 11:16 PM
04/04/16 11:16 PM
W8n2DustU
San Angelo, Texas
There were two aluminum blocks built by Mopar! A 9.6 deck and a 9.2 deck block. They are STOUT!!
