Re: 493 Build, need advice on heads!
[Re: Jpugg]
#2020738
02/27/16 02:20 PM
02/27/16 02:20 PM
Posts: 792 Earth
Rob C
Earth
[Re: Jpugg]
#2021247
02/28/16 02:02 PM
02/28/16 02:02 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Trickflow for that budget....
Ron, the TFS heads are 2k complete. They appear to come with quality parts.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Jpugg]
#2021432
02/28/16 06:09 PM
02/28/16 06:09 PM
Posts: 31,034 Oregon
AndyF
My engine has head studs already, will these work with the Trick Flows? Depends what the studs are for. Different Mopar heads require different studs. The center row of long studs need to be extra long for the Trick Flow heads. If you already have studs then just buy 10 of the longer studs and you'll be done. Trick Flow heads are about $2000 delivered from Summit and they should be ready to go out of the box. Just be sure you order the correct valve springs to match your cam specs. TF offers several different spring packages. I have an article in the current Mopar Action magazine on the Trick Flow heads if you want to see more details.
[Re: AndyF]
#2021713
02/29/16 03:51 AM
02/29/16 03:51 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thats a very good deal on the Trick Flow heads. I am very pleased with my EZ heads as Dwayne Porter gave me a good deal and they use all stock geometry valve train parts. But it sure sounds like you cant go wrong with the trick Flow. Good luck , Ron
