Re: Wiper motor bench test
[Re: 70barracuda]
#2020040
02/26/16 09:48 AM
02/26/16 09:48 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I will attach two diagrams. They show the wiring
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: 70barracuda]
#2020042
02/26/16 09:56 AM
02/26/16 09:56 AM
70Coronet500Vert
St Charles MO
Schematic B
[Re: 70barracuda]
#2020222
02/26/16 02:44 PM
02/26/16 02:44 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Thank You. Now just got to put my Electrical head on. Not to good at that, Looks like Tan wire is the feed, wish I had the wiper sw Go to www.passion4mopars.com and go to the blog/knowledge base section of the webpage to see how to test your wiper motor
[Re: 70barracuda]
#2020525
02/27/16 12:38 AM
02/27/16 12:38 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Try this
Variable Speed - Coronet (1) Connect a jumper wire between wiper motor green wire and wiper motor ground strap. Connect another jumper wire between battery negative terminal and wiper motor ground strap. Connect another jumper wire between wiper motor red and brown wires and battery positive terminal. The wiper motor should run continuously in wipe direction. (2) Connect a jumper wire between wiper motor blue wire and battery positive terminal. Connect green to brown wire. Connect another jumper between wiper motor red wire and ground strap. Connect a jumper from ground strap to battery negative terminal. The motor should run in reverse and stopbetween wiper motor red wire and wiper motor ground strap. Motor should run in reverse and stop
NS1AAR
