Operation Superbird: The Lemon-Twist Bird back to life
#2018846
02/24/16 04:39 PM
02/24/16 04:39 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
As some may, or may not know, the fruit of a long line of "Troy-trade" chapters has gotten me to this point, my own '70 Plymouth Superbird. After I sold my '70 Challenger T/A, I bought this Superbird from a friend of mine who's had it, believe since around '84/'85. He bought it off the original owner pretty much as you see it.....
Now that my job seems to be have saved with God's blessing to me, I believe I can tackle the restoration of the ole' girl.. I am looking forward in ripping through the gears with that pistol-grip 4speed....
Here are some pictures of the car as Allen found it and me hauling it home some 30 years later..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Operation Superbird: The Lemon-Twist Bird back to life
[Re: hemi68charger]
#2018848
02/24/16 04:42 PM
02/24/16 04:42 PM
hemi68charger
Houston, Tx
At home in the new wingcar nest. Here's Julie, my little mini-me messing with it already when I brought it home..
[Re: hemi68charger]
#2018849
02/24/16 04:44 PM
02/24/16 04:44 PM
hemi68charger
Houston, Tx
Assessing the car at the time.. Floor pans are in excellent shape
[Re: hemi68charger]
#2018853
02/24/16 04:46 PM
02/24/16 04:46 PM
hemi68charger
Houston, Tx
Started the disassembly process last Sunday during the Daytona 500.. Things looking good..
[Re: hemi68charger]
#2018855
02/24/16 04:49 PM
02/24/16 04:49 PM
hemi68charger
Houston, Tx
Inside the trunk, other than the typical floor trunk pan, is in pretty good shape. Luckily, I have an NOS quarter extension for the driver's side dent repair..
[Re: hemi68charger]
#2018863
02/24/16 04:56 PM
02/24/16 04:56 PM
hemi68charger
Houston, Tx
Some more of the rear window area/plug.. Overall, in petty nice shape.
[Re: hemi68charger]
#2018865
02/24/16 04:59 PM
02/24/16 04:59 PM
hemi68charger
Houston, Tx
Corner areas along with the diamond covers for the plug on the quarter seam. That filler the assembly line put on the plug seam was pretty thick.. I kept some of the material for reference later on... I can see where the transition is from across the seam.....
[Re: hemi68charger]
#2018922
02/24/16 06:28 PM
02/24/16 06:28 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Hey Troy, I tried to send you a PM, but it says that your mailbox is full. If you can, let Allen know that the old yellow Charger 500 needs to get full rear quarterpanels, and not the skins that he bought for the car. I saw a thread on DodgeCharger.com where he was looking to purchase quarter skins. Due to the car having had both a Superbird and Daytona wing mounted on it, the tops of the quarters are shot. He should get full rear quarters, and cut the inner sail panels off them, and weld them on at the window plug seams. I am glad to see that you are going forward with the Superbird project. It will a sweet car when you get it done. I hope all is well with you and your family. Thanks Pete.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: chargervert]
#2019038
02/24/16 08:51 PM
02/24/16 08:51 PM
hemi68charger
Houston, Tx
Hey Troy, I tried to send you a PM,.... Thanks Pete. Hey Pete... Thanks for the heads up, didn't know about my in box. Allen knows, I made sure he knew the extent of the sheet metal needs... But will remind him...
[Re: hemi68charger]
#2019133
02/24/16 10:55 PM
02/24/16 10:55 PM
chargervert
Thanks Troy,It is really cool to see the old 500 getting restored. When I saw Allen asking if anyone knew where to buy an AMD quarter skin,I knew that once he strips the paint off the tops of the rear quarters he would see that the car needs full quarterpanels. I know he said he bought skins. His body man had a health issue,so his project could get behind schedule. If he has to reorder the parts again later,it may cause even further delays,plus he will have less issues exchanging them now,verses waiting. You and Allen are bringing back two more Aero cars,whats cooler than that! When you get your bird done,and you are blastin through the gears,all your hard work will really pay off! Pete.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: hemi68charger]
#2020688
02/27/16 12:47 PM
02/27/16 12:47 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
The car looks really solid! Great project.
unions....the folks who brought you the weekend!
[Re: 68-scatpack-rt]
#2021236
02/28/16 01:51 PM
02/28/16 01:51 PM
hemi68charger
Houston, Tx
Operation Superbird; passenger door disassembly.. Well, today is a good day for the disassembly, pretty much have the complete door disassembled. The door, other then the dent along the body line is in awesome shape. Almost feel bad painting the inner door jambs, they are that clean.. Maybe Sunday I can get the back window assembly out. I took tons of pictures
[Re: hemi68charger]
#2021241
02/28/16 01:55 PM
02/28/16 01:55 PM
hemi68charger
Houston, Tx
More of the doors.. even the inside cat-whiskers are in great shape and I was careful to save them and reinstall. I want to save and recondition as many original parts as possible.. There's a pewter/potmetal replating company here in Houston I'll use to replate the wing window frames, door handles ( inside and out ) and Plymouth letters from the tail panel. The later I hope can be one where the crispness is saved...
Troy
[Re: hemi68charger]
#2022447
03/01/16 10:44 AM
03/01/16 10:44 AM
hemi68charger
Houston, Tx
Operation Superbird; Was able to knock out some more of the disassembly of the ole Bird.. Got the interior pretty much out and the rear passenger window. Debating on whether or not to take the rear quarter window assembly out other than the actual glass that is out now
[Re: hemi68charger]
#2022448
03/01/16 10:45 AM
03/01/16 10:45 AM
hemi68charger
Houston, Tx
back window area "stuff"...
[Re: hemi68charger]
#2035605
03/21/16 10:37 AM
03/21/16 10:37 AM
hemi68charger
Houston, Tx
Operation Superbird; passenger door disassembly.. Well, today is a good day for the disassembly, pretty much have the complete door disassembled. The door, other then the dent along the body line is in awesome shape. Almost feel bad painting the inner door jambs, they are that clean.. Maybe Sunday I can get the back window assembly out. I took tons of pictures.
[Re: hemi68charger]
#2035607
03/21/16 10:38 AM
03/21/16 10:38 AM
hemi68charger
Houston, Tx
Interesting way to secure the back of the headliner to the package tray....
