Clearancing SB for 4" crank and Eagle rods
#201834
01/23/09 11:31 AM
01/23/09 11:31 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Where all will I need to clearance the block when running a 4" crank and Eagle rods in a small block. It's a 318 block. I'm guessing the bottoms of the cylinders for the rod bolts and possibly the pan rails?
I've never build a SB stroker so this is new to me, looking for some input.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Clearancing SB for 4" crank and Eagle rods
[Re: WadeMetzinger]
#201841
01/23/09 12:00 PM
01/23/09 12:00 PM
Posts: 407 Great White North Werst coast
runya
I used a K1 crank and rods, and did have to do some clearancing around the main webs also (very little but did need some). If I remember right I used 1/16" aluminum under the pump with no gaskets, just make sure the spacer is flat and no burrs. ![](http://i403.photobucket.com/albums/pp119/Russ410/CopyofPicture040-1.jpg)
[Re: MR_P_BODY]
#201842
01/23/09 12:03 PM
01/23/09 12:03 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Alot of you guys take pics of everything, some day I'll learn to do that also
Not everything!
Pictures save me words.....I don't always articulate my thoughts so other people understand me. Please, no comments. ![](/ubbthreads/images/graemlins/biggrin.gif)
Martin CC 2007
[Re: S/ST 3040]
#201843
01/23/09 12:18 PM
01/23/09 12:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not everything!
Martin CC 2007
Thats the same way I feel.... and it would be alot easier than trying to spell it all out ![](/ubbthreads/images/graemlins/grin.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#201844
01/23/09 01:34 PM
01/23/09 01:34 PM
Posts: 381 Denver CO
bennydodge
Denver CO
I'm running Eagle H-beams in my 340 stroker. I had to notch the bores but my oil pump cleared just fine(MP high vol., MP 4" cast crank).
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
[Re: bennydodge]
#201845
01/23/09 04:04 PM
01/23/09 04:04 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Here is the clearancing that I did.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
